Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-06-2007, 02:15 PM
1994 Ford MN is starting off with a positive reputation.
Radiator leak repair help!!!!!
I have a 1994 Ford Ranger V6 3.0 with a leaky radiator. It has a lot of miles on it and I would rather try and fix the leak instead of buying a new one. I tried the Bar (i think that is the brand) quick fix leak ender crap, and of course it didn't work. I was thinking i could maybe solder it? Does anyone have any recommendations or procedures to follow. I know how to solder, I just need some directions. Thanks in advance.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 11-06-2007, 03:53 PM
ynevada is starting off with a positive reputation.
isnt that a plastic tank on there?
wheres the leak coming from?
its got alot of miles, even if its a metal tank, the rad might not be worth fixing.
put in a new one, and you wont have to worry about when it leaves u stranded somewhere.
  #3 (permalink)
Old 11-08-2007, 04:44 PM
Corey872 is starting off with a positive reputation.
Good questions above. I've had good luck with Barrs on a couple of old bombers, but you have to follow the directions exactly - and ideally, flush the system before use.
If the radiator is copper, all you need to do is clean the area, apply flux and solder. Be sure you have a big enough heat source (likely a propane torch) to heat the area. Your 25watt electronics soldering iron won't be up to the task. If it is aluminum, conventional solder won't work, you may be looking at some of the special aluminum welding / brazing rods.
__________________
Corey
04 Scab 5.4L XLT 4x4
93 XLT 5.8L - RIP
  #4 (permalink)
Old 11-08-2007, 04:47 PM
oh i forgot to mention chemical repairs(barrs leak) should be used as an EMERGENCY repair ONLY.
they are disasterous on heater cores. if there is any kind of build up on the cores, the barrs will adhere to it and clog it.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
