Hey, new here. 66 f100 need gas tank..help
Hey guys,
My name is Mike. I am a Service Writer for an Autoshop "carmasters automotive" in virginia beach, virginia. We are restoring a 66' f100 pick up truck for a customer and well, the gas tank has holes and is beyond feasable repair. I cannot source a gas tank anywhere...even online. I need you alls help What do you recommend doing? I was never a fan of the behind the seat tank anyways. Please help, I'll check this every other hour
Thanks,
Mike
Thanks,
Mike
Originally Posted by Carmasters
Hey guys, My name is Mike. I am a Service Writer for an Autoshop "carmasters automotive" in virginia beach, virginia. We are restoring a 66' f100 pick up truck for a customer and well, the gas tank has holes and is beyond feasable repair. I cannot source a gas tank anywhere...even online. I need you alls help What do you recommend doing? I was never a fan of the behind the seat tank anyways. Please help, I'll check this every other hour
Thanks, Mike
Thanks, Mike
The 1961/66 18 gallon fuel tank was replaced by Ford with the 1967/72 19.5 gallon fuel tank (Ford p/n: D0TZ-9002-A). The only difference besides the capacity is one fitting. The fuel sender is the same 1961/77. I know where some are, but they're a bit far away...in SoCal.
You might contact FTE sponsor Green Sales in Cincinnati, Ohio (800-543-4959) and see if they can help. Green is one of the largest Ford obsolete parts sellers in the world. Other sources: Dennis Carpenter in Concord, NC, or joblotauto.com in Queens, NY.
Originally Posted by rogue40
I don't like in-cab tanks either.
I plan to fab a tank that will fit inside the frame behind the rear end for both my slicks.
The only problem with this is finding a sending unit that works with the stock fuel gauge.
Does anyone have any suggestions?
I am curious as well. The behind-the-seat situation is not the safest and I can't quite get the gasket to seat properly. . .
-J
First and Foremost, Welcome to FTE. I prefer purchasing from FTE sponsored companies if possible, but occasional will go with a particular supplier if not familiar with the quality of other. Anyhow, purchase number of items from Classic Auto parts but it was few years back when they were called Obsolete Ford Parts, that's before fomoco threatened suit if they did not change company name. Anyhow, always satisfied with the quality of the merchadise and they are located in great state of Oklahoma, online catalog shows they carry the fuel tank suggest call and inquire. Also included couple articles on moving the fuel tank. Suggest run a search and narrow search to 61-66 forum, topic has come up on number of occasions.
http://www.classicautoparts.com/
http://www.angelfire.com/mech/jims65...nkinstall.html
http://www.classictrucks.com/tech/04...all/index.html
dave
dave
Believe it was in Classic Truck magazine where they had pic's of access door in middle of bed, may still have the article, could not find it online. It certainly looked good but imagine a pain in the backside if intend using the bed. Suggest run a search on topic, if recall, member posted pic's where he routed filler neck just above bed rail. I would probably install a flush access panel on the bed rail and run filler neck to it. Anyhow, additional food for thought.
dave
dave
Here is ALL the info you will need https://www.ford-trucks.com/Go to the technical section
