Diagnostic equipment for EEC-IV.......PICS - Ford Truck Enthusiasts Forums
Old 11-05-2007, 09:52 PM
eco eco is offline
eco is starting off with a positive reputation.
In a recent thread some folks did not seem to be aware of what is available to trouble shoot these rigs. The scanners out (generic and manufacturer specific) there don't do much for OBD-I since there is no "Data Link Connector." However, many of the functions that modern scanners (Snap-On Modis, MAC Mentor, manufacturer specific scaners) allow one to do on OBD-II rigs (and then some) can be done with the EEC-IV ODB-I rigs too. It's just a matter of knowing what is available and where to get it. Over the years I have accmulated a fair amount of EEC-IV specific test equipment, and I will share with you what it is and what it does
The most usefull of the EEC-IV specific tools is the Monitor. It hooks up in series with the computer and the wiring harness. It has a built-in digital display (for volts, ohms, mSEC, hz, DEG...which ever you choose) that you can set where ever you want within a 5 feet range (roughly) which comes in handy for test drives. You can choose to display whatever you want...be it TPS, MAP, MAF, coolat temp sensor, fuel injector pulse width.....whatever. The big fat **** with the blue and pink around it is used to select what get displayed on the digital display. The Monitor also displays the firing of the injectors in real time, the spout (whether or not it is hooked up), the switching of the O2 sensor(s) in real time, the TAD and TAB and much more all with a series of LEDs. Each application calls for a different overlay. I use the 92 Mustang overlay since that is the computer that I have. If anyone here gets a Monitor but needs an overlay, I can likely hook you up. I have almost every overlay that was made. The Monitor also came with a couple thousand pages of text to troubleshoot, I have that too. This is just the tip of the iceberg regarding what the Monitor can do.
This is the Monitor Recorder. It allows you to record up to 8 channels of what the Monitor sees. You can record up to a certain amount of time (10 minutes I think, just push the START RECORD button) and when you are done you hit CAPTURE. You then playback the channels you recorded 1 or 2 at a time. The data either displayed on the digital readout, the analog readout (both are on the Recorder) or an external volt meter or scopemeter of your choice. It hooks up to the Monitor via PORT A and PORT B.
This is a fuel pressure gauge and a vacuum gauge...it can be used for either. The data that this reads can be inputed to the Monitor or displayed on a volt meter or scopemeter of your choice.
In many cases the Monitor (and breakout boxes) can be a pain to install due to space issues. This relocates everything and makes the hook up of the Monitor a cake walk.
This is used to alert the driver that a trouble code has been logged into the EEC-IV. It hooks up to the test connector. When a code gets logged, it beeps. It is usefull on test drives + it also beeps on continuous memory codes...the ones that don't light up the CEL.
A TFI bench tester....fairly straight foreward what it does. Plug it in, push the button. If it does not find a fault, both LEDs light up. Not the greatest, becuase it does not catch the problems that cme and go and it does not give much info.
This is the best TFI ignition system diagnostic tool out there as far as I am aware. If hooks up in series with the TFI module and has a series of LEDs that tell you what is going on. I will also diagnose a no start condition. It has a little breakout box off to the side so that you can measure the signal going through any given wire associated with the system. It comes with a manual that tells you how to trouble shoot based on any given LED indicated fault.
This is a breakout box. Not quite as handy as the Monitor, but it does have it advantages. I like to use it in conjunction with a scope meter so that I can graph the data in relation to a given time frame. This is good because I can then catch things like a bad spot in a TPS (or any sensor for that matter) that any old volt meter or even the digital read out on the Monitor wont catch because it is not fast enough. A scope meter will catch ANYTHING. This is the OTC version. These allow you to probe any of the 60 pins that plug into the EEC-IV quickly and easily.
This is the Thexton breakout box. Different construction, but it does the same thing.
Old 11-05-2007, 09:57 PM
flareside_thunder flareside_thunder is offline
flareside_thunder is starting off with a positive reputation.
Wow, eco......goodluck with that....looks ummmmm confusing to say the least......please tell me you wing it with all that stuff.....then I wouldn't feel too much like a moeran......Later on
JR
Old 11-05-2007, 10:02 PM
eco eco is offline
My Fluke scopemeter...
This is a diagnostic cable so to speak that hooks up in series with various parts of the ignition system then plugs into a breakout box. This is nice because the whole ignition system is layed you right in front of you and it is easy to get reading. No more fussing around with back probing.
Volt meter and amp clamp.....fairly straight foreward.
This is my exhaust gas anayzer. Hands down the best way to know how a motor is running. It is non-intrusive and will tell you whatever you need to know.....if the motor is running rich, lean, missfire etc.etc. Everything gets displayed on a laptop and it runs on OTC Microgas software.
This is a smoke machine. It finds leaks of all kinds...mainly used for vacuum leaks and evap leaks....but for these rigs not so much on the evap system. It also works for finding oil leaks in newly assembled things like rear ends, manual steering boxes etc.
Old 11-05-2007, 10:05 PM
Skandocious's Avatar
Skandocious Skandocious is offline
Skandocious is gaining momentum as a positive member of FTE.Skandocious is gaining momentum as a positive member of FTE.
Damn dude... I'm at a loss for words. Haha. Wanna come out to CA and test my truck for me? All that stuff looks really complicated...
Old 11-05-2007, 10:28 PM
eco eco is offline
Quote:
It's really not that complicated. It's basically an analog scanner broken up into several different items....you know...dinosaur technology. Instead of scrolling through various screens to find a certain function, everything is layed out in front of you. Funny thing is, this stuff can be had for very cheap. On top of that, half the time when I run into this stuff it looks like it was sent to the dealership service depatment, set in a corner and never touched (the Rotunda stuff that is). For some reason those dealer techs did not bother using this stuff. I wish I could figure out why because as far as I am concerned this stuff works great. The only things that really costed me some serious coin was the smoke machine, gas analyzer and the scopemeter. The Rotunda stuff costed me anywhere from 10 dollars to 150 dollers per item.
Old 11-06-2007, 12:13 AM
Scndsin's Avatar
Scndsin Scndsin is online now
Du Nawt Seek The Treasure
Scndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputation
Quote:
Originally Posted by eco
.... Funny thing is, this stuff can be had for very cheap. On top of that, half the time when I run into this stuff it looks like it was sent to the dealership service depatment, set in a corner and never touched (the Rotunda stuff that is)........
....For some reason those dealer techs did not bother using this stuff.
.....The Rotunda stuff costed me anywhere from 10 dollars to 150 dollers per item.
HeyZeus H. Crispus!... That's close to 10 to 20K in original equipment cost for all that Rotunda stuff! Where the hell do you shop?????
2 break out boxes this guy has... 2!
Old 11-06-2007, 12:29 AM
ford2go's Avatar
ford2go ford2go is offline
ford2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud of
Yes, where do you shop? I'd love to have a BOB and a lot of that other stuff -- and for OBDii stuff as well.
ford2go
Old 11-06-2007, 08:19 PM
eco eco is offline
Quote:
Auctions. Whenever a stealership shuts down, cleans house etc. they auction off this kind of stuff. These Rotunda tools in addition to service manuals (I got a bunch of those too) and other odds and ends get sent to public auctions and online auctions such as eBay. Right now there is a bunch of these same tools on eBay. The beauty of it all is that the majority of what I got was still in the factory packaging....unopened.
Old 11-07-2007, 01:29 AM
KDPate's Avatar
KDPate KDPate is offline
KDPate is starting off with a positive reputation.
Damn eco, you're set to diagnose any ford OBD-I system.
Now I feel sheepish for using and Actron scanner and a Fluke multimeter......
Old 11-07-2007, 08:58 AM
Scndsin's Avatar
And people wonder why their dealerships can't fix their #*%!@ vehicles...
Old 11-07-2007, 11:26 AM
89frankenford's Avatar
89frankenford 89frankenford is offline
89frankenford is starting off with a positive reputation.
WHOA!!!!! good finds..no GREAT FINDS! i should have gone down to the dealership that just got bought out and shut down!! i could have nabbed some of that stuff
Old 11-08-2007, 01:10 PM
eco eco is offline
Quote:
Is ebay an option for you? If you get a monitor and need the overlay I can probably hook you up. They only go for about 75-150 dollars on the norm.
Old 11-10-2010, 09:19 PM
mmcss640 mmcss640 is offline
mmcss640 is starting off with a positive reputation.
Eco, I'm buying a used Monitor and I'm not sure if the manual is included / available. Have you scanned your Monitor manual into pdf format? I would be interested in obtaining a copy. Thanks. Old Ford Instructor
Old 11-11-2011, 02:13 PM
Paul2020 Paul2020 is offline
Paul2020 is starting off with a positive reputation.
Sure Proof Test for TFI ?
Eco and friends!
I've done a lot of reading the last couple days on the TFI failures in the older model Fords. I have an 1988 E-150 conversion van in very good condition except for this stalling out, no start problem. It looks like there was a major issue and a major lawsuit that Ford settled out of court around 2001. A known issue involving random TFI failures due to overheating of the unit.
I read some people's experiences about replacing a brand new TFI module that tested good with another brand new one and it corrected the no-start problem.
Conclusion: The standard tests from before cannot always detect a bad TFI.
A TFI replacement story:
http://www.ford-trucks.com/forums/91...stributor.html
Suggested Testing Procedures that reportedly don't always show a bad TFI:
Ford Ranger/Bronco II TFI Ignition Diagnostics
I am wondering two things.
1) Does the Ford Rotunda TFI tester give a more accurate test than anything else? From the article number (87-21-10) issued by Ford it looks like it might have come out in 2010?
If so, where in the world can I get one reasonably? I haven't been able to locate anything yet on eBay or by searching for Ford dealer out-of-busines auctions.
2) Motocraft TFI's are quite expensive. I can get one at near wholesale for between $100 and $150 plus shipping. What aftermarket brand is the next best option in your opinion?
Thanks!
Here is Ford's published article on the new test procedure:
EEC IV - TFI MODULE AND PIP SENSOR - Article No. 87-21-10
NEW DIAGNOSTIC PROCEDURE
LINCOLN-MERCURY: 1983 MARK VI
1983-86 CAPRI 1983-87 LYNX 1983-88 COUGAR, MERCURY, CONTINENTAL, LINCOLN TOWN CAR 1984-88 TOPAZ, MARK VII 1986-88 SABLE
MERKUR: 1985-88 XR4Ti 1988 SCORPIO
LIGHT TRUCK: 1983-88 ALL LIGHT TRUCK LINES
ISSUE: A new diagnostic procedure for testing the TFI module and PIP sensor has been developed. This new procedure allows the technician to take a direct path when testing the TFI module and PIP sensor with the use of the new TFI IV diagnostic tester (Rotunda No. 105-00003).
ACTION: If service is required, use the diagnostic procedures on pages 29 through 60 of this TSB. Insert these pages in the Engine/Emission Diagnosis Manual, Volume H, Section 15.
OTHER APPLICABLE ARTICLES: None
WARRANTY STATUS: "INFORMATION ONLY
Old 11-12-2011, 05:05 PM
89lilfoot 89lilfoot is offline
89lilfoot is starting off with a positive reputation.
If I had that kinda money. Don't you think I'd be sportn a brand new rig. Who do you work for? Sale rep?
Westin Brush Guard Install with pics rockstate45 2004 - 2008 F150 3 12-17-2014 05:23 AM
New steering Wheel High Intentions Excursion - King of SUVs 40 10-21-2012 02:41 PM
Help installing driveshaft hanger/center/carrier bearing BigMikeUGA 1961 - 1966 F-100 & Larger F-Series Trucks 7 12-31-2011 08:38 PM
Power Brake Booster Boot BigMikeUGA 1961 - 1966 F-100 & Larger F-Series Trucks 14 07-08-2011 12:56 PM
59 coe build 48fordcoe 1948 - 1956 F1, F100 & Larger F-Series Trucks 20 12-24-2008 04:07 PM
Tags
1988, box, break, breakout, computer, diagnostic, eec, eeciv, ford, homemade, iv, mac, mentor, monitor, overlay, overlays, rotunda
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
