fuel filter help needed now!
I realize I'm probably just a moron but I took out the old fuel filter and can't get it removed from the top. The one I bought has instructions and it doesn't tell you how to remove the old filter from the plastic top. Do I have the wrong filter? I thought this was going to be easy, man nothing ever goes smooth for me.
Originally Posted by jboard
Some give you a new cap and some dont...just pry the filter away from the cap and it will pop loose.
---------------------Jeremy
No as long as the filter looks the same its fine...some manufactures include the cap, but some dont the last one I bought didnt give me the cap either...depending on the kind of cap you have if it has little tabs then be careful not to break the tabs but I believe ther pretty strong. The other kind has no tabs and the filter will pull off with some force.
Well I've tried prying the dang thing out and have gotten no where. Do they come with the top already on where you just screw them on. Seriously this is crazy. Should I just take the one I bought back and see if they have the one with the top already on it? I've messed up the old filter so it ain't going back on.
Yep..I am ordering a new cap today as I finally found tht to be my fuel leak source. Afer 2 weeks of trying to find the sucker, a dye test reveealed the cap leaking. y2kford parts was cheapest for an OEM cap with the tabs at $11.90, and powerstrokeshop.com was a buck more. OEM came with a re-useable cap.
Bad Bad Leroy Brown
09-28-2012 01:45 PM
artfd
01-01-2012 08:13 PM
