You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Well since I have a truck I am getting hit for a 250ish "weight" fee. Ya it's normal, but I was told if you have a camper shell on the truck they don't charge this fee.. Is there any truth behind this?
I've already accepted the 350ish registration fee that's due in a couple weeks, but I figured I'd try to save a few dollars.. (Don't we all want to save a few dollars?)
Thanx for any input.
__________________
Vic W6VIC
2001 F250 6" lift on 37's
87 Bronco 96-351, 78-C6. SAS 9" SL with 3" BL on 40's
2007 R1
__________________
Cheers
Colonel Flashman
Vermilion '58 Mercury M-100 HP 312 I-6 w/ HP C-4
Blue '58 Mercury M-100 Panel 223 I-6 w/ M-O-M
Black 1893 Henry Ford Quadra-Cycle (replica) My Replies Are Not Meant In An Offensive Way.... Ever, They Are Merely.... Straight Answers or Comments
Try searching the CDMV URL below. http://www.dmv.ca.gov/
Best I'm able to do for you, as this is where I originally found the Intele myself.
__________________
Cheers
Colonel Flashman
From what I understand since you are registering a "commercial" vehicle you have to pay by weight. If you are stopped and weighed you need to be at or below the weight listed on the registration. If not you can incur a fine.
I know because I have been there...I did not get a ticket, but the it was close. The fine is typically back paying what you weight at that time to the begining of the year plus some more $$$.
Just sonther tid bit fot ya...if you use a SRW to tow DO NOT exceed the max per tire weight for EACH tire. I was weighed with scale for each rear tire and they looked at the load rating of the tires...I had E rated tires, but they said if I had D tires I would have over weight for the tire and gotten a ticket. They also checked to see that I was not over the trucks GVRW. They said they rarely give a ticket for exceeding the trucks GVRW since it is easy to bolt on aftermarket gear to increase that number, but you cannot bolt on anything to increase the max weight your tires will carry.
