2007 6.0 oil leak - Ford Truck Enthusiasts Forums
2007 6.0 oil leak
Old 11-05-2007, 02:23 PM
torino_gt torino_gt is offline
torino_gt is starting off with a positive reputation.
2007 6.0 oil leak
i was changing my oil and looking around the motor and dicovered an oil leak on the drivers side, back of head. it looks as if it is coming from above the bottom of the head. it is a very minor leak but still wet. i could not see where it could be coming from. oh yeah...20k miles
Old 11-05-2007, 02:30 PM
blackhat620's Avatar
blackhat620 blackhat620 is offline
blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.
Quote:
There are several things that could be causing the leak. Take you truck in and have the tech put dye in the oil so that the leak can be properly traced and fixed.
Old 11-05-2007, 02:42 PM
moebdick's Avatar
moebdick moebdick is offline
moebdick is starting off with a positive reputation.
I had same thing at about 10k and it was the glow plug connector. Dealer confirmed with dye and replaced buss bar. No more leak.
Old 11-05-2007, 02:55 PM
thanks...now just have to wait 3 weeks for an opening at the dealer
Old 11-05-2007, 03:57 PM
18vtx00's Avatar
18vtx00 18vtx00 is offline
18vtx00 is starting off with a positive reputation.
we have no waiting, where are you from??
could be several things, visual inspection and then add uv oil dye if you cannot visually tell..
Old 11-05-2007, 06:09 PM
wv, i know there is a wait because my dad had to make an appointment for his 7.3...
well it is right on the corner of the head but more on the rear side of the corner. and the oil looked clean
Old 11-05-2007, 06:38 PM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
As others already posted:
The oilcould be coming from one of MANY places. You need to run it by the dealer and let them look at it. More than likely, they will add some dye to your oil, have you put a some miles on it with the dye, then have you bring it back in so they can locate it with a lamp.
<O</O
Generally almost all oilleaks end up running onto the rear of the motor, bell housing and transmission.
The most common leaks on the <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com[img] /><st1:NumConv6p6 val=[/img]6.0</st1:NumConv6p6> are as follows in descending order of occurrence: (Notice the First for items comprise <st1:NumConv6p0 val="65" sch="1">65</st1:NumConv6p0>% of all reported leaks and are a simple fix.)
NOTE - this comes from a previous post from Blackhat<st1:NumConv6p0 val="620" sch="1">620</st1:NumConv6p0>
CAC Tubes =
<st1:NumConv6p0 val="21" sch="1">21</st1:NumConv6p0>%
ICP Sensor =
<st1:NumConv6p0 val="16" sch="1">16</st1:NumConv6p0>%
Glow Plug Harness =
<st1:NumConv6p0 val="14" sch="1">14</st1:NumConv6p0>%
Cam/Crank Position Sensor =
Front Crankshaft Seal =
<st1:NumConv6p0 val="8" sch="1">8</st1:NumConv6p0>%
Upper to lower block seal (skirt) =
<st1:NumConv6p0 val="5" sch="1">5</st1:NumConv6p0>%
HPOP cover =
<st1:NumConv6p0 val="4" sch="1">4</st1:NumConv6p0>%
Oil Cooler (this leaks into engine coolant) = <st1:NumConv6p0 val="4" sch="1">4</st1:NumConv6p0>%
Front or Rear Engine Cover =
<st1:NumConv6p0 val="3" sch="1">3</st1:NumConv6p0>%
Rear Crank Seal =
Turbo Charger & VGT actuator =
<st1:NumConv6p0 val="2" sch="1">2</st1:NumConv6p0>%
Covers (
oil pan, valve covers, breather) = <st1:NumConv6p0 val="2" sch="1">2</st1:NumConv6p0>%
Cracked or Porous Block or Head =
<st1:NumConv6p0 val="1" sch="1">1</st1:NumConv6p0>%
IPR valve/Engine Lube
oil pump = <1%
ALSO -
<O</Ohttp://www.forddoctorsdts.com/photographs/index3.php
Great information site as well.
Question about new oil Leak crlrca 6.0L Power Stroke Diesel 3 07-06-2011 12:15 PM
Oil leak by the filter 72mach_1 Explorer, Sport Trac, Mountaineer & Aviator 13 09-14-2005 06:29 AM
oil leak PCola Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 05-17-2005 06:45 AM
oil leak ford390gashog FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 10 11-20-2004 11:35 PM
Leaking head gasket debestuss FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 03-13-2004 02:17 PM
Tags
04, 2007, 60, diesel, driver, edge, f250, ford, leak, leaking, leaks, motor, oil, power, powerstroke, recalls, side, sport, stroke, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
