1956 F100 with no spark??
No Spark
If your condenser is bad = no spark . Are you getting power to the points??
Do the points spark when you spin the engine over ? This sounds like a dead
condenser or coil. Rule of Thumb If the Dwell is too BIG! the gap is too small
& if the Dwell is too small the gap is too BIG!
Have A Good Day----Hotwrench
Spark!!
Hello,
OK I now have confirmed the coil is good by "tricking" it by grounding the - side of the coil. That eliminated everything from the coil back to the ign. switch. It has to be the distributor. Today I am going to go get new points and condencer. Hopefully tonight it will start.
Thanks!
Thanks!
ymirr
04-06-2017 07:42 PM
Aircraft Tech
06-23-2016 10:50 AM
