Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-04-2007, 09:35 PM
Abbie is starting off with a positive reputation.
Adding DRL to 2007 F150
Do the 2007 F150's still use the Relay & Resistor to enable Daytime Running Lights? (PN's YL1Z-13B218-AA /XL3Z-14A601-AA)
I have read a few articles indicating that these are the part numbers to use in order to activate the DRL's on 1999 & newer F150's. I just want to confirm that this is the same procedure for 2007 trucks, and that Ford hads not gone to programmable DRL - SJB (Smart Junctoin Box) on the F150.
Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 11-05-2007, 08:19 AM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
I don't have any info on a truck that late. Sorry. Would the dealer be any help?
I see you live in Canada, and we get this question once in awhile. I have heard they require DRL's in Canada. They make you add DRL's even though the truck originally did not have them? Is there a cut-off date of manufacture for adding DRL's or do they force you to have them on everything, even a 50's or 60's type car?
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 11-05-2007, 08:50 AM
Thanks Dave. In Canada, DRL's have been mandatory sine the 1992 Model year. - Anything before that does not need to be retrofitted . There just seems to be some confusion at the dealer concerning the Ford parts required for conversiion to DRL for the 2007. I can get an aftermarket kit to use the fogs. - which I may do in the end if it proves costly to go OEM.
FYI, Here is a link to the Canadian regs regarding Daytime Running lights.
http://www.tc.gc.ca/acts-regulations/GENERAL/m/mvsa/regulations/mvsrg/100/mvsr108.html#Daytime_Running_Lamps
  #4 (permalink)
Old 11-05-2007, 11:46 AM
Mil1ion has much to be proud ofMil1ion has much to be proud ofMil1ion has much to be proud ofMil1ion has much to be proud ofMil1ion has much to be proud ofMil1ion has much to be proud ofMil1ion has much to be proud ofMil1ion has much to be proud ofMil1ion has much to be proud ofMil1ion has much to be proud of
I have a link to this on my web site.
I don't know how old the page is.
http://www.users.voicenet.com/~storm/drl/
  #5 (permalink)
Old 11-06-2007, 08:59 AM
Thanks for the info & the link. As you suggest, this site does not have a date, and my truck does not have the cap on the plug - suggesting that DRL installation on late model F150's is different.
I am still waiting for info from Ford
  #6 (permalink)
Old 02-27-2008, 12:02 PM
CrazyCorey is starting off with a positive reputation.
What did you end up doing?
Abbie, What did you end up finding out? I am trying to do the same thing right now. Thanks, Corey
  #7 (permalink)
Old 02-28-2008, 04:07 PM
drls
ended up putting on an aftermarket kit.
  #8 (permalink)
Old 02-28-2008, 04:46 PM
Me too, installed mine last night. Works well.
Cheers,
Corey
  #9 (permalink)
Old 04-01-2008, 08:04 PM
klsparrow is starting off with a positive reputation.
Smile
Quote:
Cheers,
Corey
Whay kit did you use for the DRL. On the 2007 where does this mount. I have a 2008 F150 and I want to check and see if this is where mine would mount.
Tanks
klsparrow
  #10 (permalink)
Old 04-02-2008, 08:28 AM
I just used 2 sided stick tape and mounted the module in front of the battery. After I hooked up to the factory wires I used black wire loom like the factory to cover the wires. Everything looks stock now. Where do you live, I am in Canada and they are required. You can get the module at Canadian tire.
Cheers,
Corey
  #11 (permalink)
Old 04-02-2008, 08:40 AM
I live is Conway, Arkansas USA. I am trying to find out where this would go on the 2008. I don't even know if it has a loop back plug. Don't know where to look. Heck I cannot even find a 2008 repair monual for 2008 f150. I will see if I can find Canadian Tire.
Thanks
Ken
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
