Is My Fuel Tank Selector Valve Going Bad?
I've heard about this problem before from reading the forums.
So here's what my truck did.
I have a dual tank set-up in my 93 f150. I replaced the front tank a couple months ago with a used tank/fuel pump. The sending unit doesn't work, but the fuel pump does and I was happy to have two tanks with working pumps.
When I fill up, I fill both tanks. This last time I drove on the rear tank till it was down to about 1/4. Then I switched to the front tank which is alway son E(mpty) because the sending unit doesn't work. But while I was going down the highway, it started running out of gas as I was talking on the phone with my girlfriend. I hit the tank selector switch on the dash and switched back to the rear tank, and the gauge went up to 1/2 tank, even though I'm sure it wasn't more than 1/4 full when I last used it.
So is that my fuel tank selector valve going bad and pumping the returning fuel to the rear tank instead of the front?
I picked up a new part this weekend, but I looked under there i can't even find the damn thing.
The following 2 users liked this post by subford:
Originally Posted by subford
A 1993 does not have a selector valve.
Only the selector switch on the dash.
You have a bad check valve or shuttle valve in your rear Fuel Delivery Module (assembly)./
So the fuel from the front tank is being returned to the rear tank because the rear tank module's check valve isn't functioning properly?
According to others here, Ford stopped using the Dual Function Reservoir sometime in 1990. I assume you have already read the whole thread and already know the answer to your question which is “yes”.
