power window failure - help
Hello all:
I have a driver window in the "all the way down" position that won't come back up. After removing the moisture barrier and checked the circuit, I've determined that the motor is receiving power. When I press the switch to move the window down I hear a click and can feel it in the motor as well. When I press the switch to move the window up, there is nothing - no sound or movement.
Is the motor my problem or is it something else? Trying to lift the window while depressing the switch does nothing.
The generic manual I have indicates that removing the regulator and motor can be dangerous? Is it? Is it tricky? I don't understand their instructions.
Any advice would be greatly appreciated - it is colder than a witches @#$ here.
Thanks,
Chris
Thanks,
Chris
There is more danger damaging the charger than the window motor. Most battery chargers have circuit breaker. As long as the charger is protected with a circuit breaker, it will work. You could also use the truck battery, but you have to be careful and not let the wires touch together, the battery has a lot of power behind it.
re: power window failure - help
Thanks Dave:
The charger didn't work for me but the direct battery hookup did. Since I was able to get the window back up this way does this mean that my problem is definitely the switch? I've read some things about a one-touch down relay. I wouldn't think this is the problem because my window wouldn't go "up" (as opposed to down), but I don't know much about these things.
Can this switch be bought from somewhere other than Ford? The two local suppliers I've checked so far can't get it for me.
Thanks again,
Chris
Thanks again,
Chris
mrjimbov
Electrical Systems/Wiring
11-23-2014 07:20 AM
mike L
09-23-2013 09:42 AM
