6.0 fuel problem - Ford Truck Enthusiasts Forums
6.0 fuel problem
Old 11-04-2007, 05:11 PM
xcnick38 xcnick38 is offline
xcnick38 is starting off with a positive reputation.
6.0 fuel problem
the other day i took my 03' 6.0 to the local lube station... got the auto tranny done, front + rear diff, transfer case and engine... i also got the fuel filter(s) changed, which is where my problem lies... on what im told is the lift pump (infront of tank along frame) where the one filter goes, it is dripping diesel out from around the black cap the filter goes inside... im guessing there is some type of seal or o-ring that goes there that could have possible been broken... how ever i don't have a socket that will fit it so i can remove the cover to check...
but now to the problem, since i got it back it takes for ever to start, and when i turn the key to the "on" position to get ready to start there is a weird grinding noise that sounds like its comming from the front of the engine compartment, it does it every time i turn the key from the off position to the on position, and then when i try to start it it takes a long time for it to fire, my friend and i were discussing it yesterday and we think it may be the lift pump (where the filter is i explained earylier) is bad or it is sucking air around the cap of the fuel filter... i remember reading some where that the powerstroke has a unique fuel injection system that is high pressure and either 10,000 PSI or somthing, so i figure with the high pressure injection system like that even a small air leak could cause a huge problem...
this is my first diesel vechicle and im not to familiar with how everything works... if the lift pump is bad, im thinking of going with a fass fuel, glacier diesel or another type of aftermarket lift pump...
what are your suggestions or thoughts on this?
any info is greatly appreciated...
thanks
nick
Old 11-04-2007, 06:15 PM
BowTieHatr BowTieHatr is offline
BowTieHatr has a very good reputation on FTE.BowTieHatr has a very good reputation on FTE.BowTieHatr has a very good reputation on FTE.
fix the fuel leak first. you are probably losing prime on the fuel side. its a 36mm hex and yes there is a oring on there. if a quick lube did it, you probably have the wrong filters in it anyway so you may want to get the right ones and do it yourself.
Old 11-04-2007, 09:57 PM
3000 FPS's Avatar
3000 FPS 3000 FPS is offline
3000 FPS is gaining momentum as a positive member of FTE.
If you go on ebay you can find sockets that fit the cap for the fuel filter that is down on the frame.
Old 11-04-2007, 11:55 PM
doubledee715's Avatar
doubledee715 doubledee715 is offline
doubledee715 is starting off with a positive reputation.
search jiffy lube on you tube and you'll never take any of your vehicles back again.
Shock Life ccecilm2 2004 - 2008 F150 20 02-18-2009 09:13 PM
22" Tires and Wheels samurai 2007 - 2014 Expedition & Navigator 0 12-02-2007 09:07 PM
1995 F350 460 Engine Tuning macwilj 1987 - 1996 F150 & Larger F-Series Trucks 1 07-28-2007 09:26 PM
Disable Wastegate Actuator? MrNuckelhead 1999 - 2003 7.3L Power Stroke Diesel 11 07-09-2007 08:39 AM
V10 Fuel System E85-Q&A?? F250XL Fuel Injection, Carburetion & Fuel System 1 06-24-2007 02:29 AM
Tags
60, fuel, problems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
