Vacuum Pump to Remove oil from HPOP - Ford Truck Enthusiasts Forums
Old 11-03-2007, 09:21 PM
bkcowboss bkcowboss is offline
bkcowboss is gaining momentum as a positive member of FTE.
Thumbs up Vacuum Pump to Remove oil from HPOP
Here is a link to a thread I posted in the 94.5-97 forum has pics and application for a pump to remove oil without out a gravity drain option, hope it helps out
http://www.ford-trucks.com/forums/66...from-hpop.html
Old 11-04-2007, 12:07 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
PowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to behold
everytime i change oil on a 7.3 powerstroke i suck the oil out of the HPO reservoir, because of the fact it gets alot more dirty oil out and clean oil in.
Old 11-04-2007, 12:42 AM
mech2161's Avatar
mech2161 mech2161 is offline
mech2161 is gaining momentum as a positive member of FTE.mech2161 is gaining momentum as a positive member of FTE.
Here's what I have. 07300 PneumatiVac Second one down on this page.
http://www.mityvac.com/pages/products_fee.asp
Question - need suggestions - 97 7.3 PSD no start HPOP? Rob Carpent 1994.5 - 1997 7.3L Power Stroke Diesel 7 06-07-2014 11:05 PM
Question - looking for suggestions - 97 7.3 no start possible HPOP? Rob Carpent 1994.5 - 1997 7.3L Power Stroke Diesel 2 05-28-2014 12:11 AM
hpop and stage 2 injectors frdf250 1999 - 2003 7.3L Power Stroke Diesel 23 01-26-2010 10:13 AM
New HPOP, still no oil pressure chintonmd 1994.5 - 1997 7.3L Power Stroke Diesel 39 10-20-2008 08:54 AM
That Sucker mueckster 1999 - 2003 7.3L Power Stroke Diesel 29 08-01-2008 12:04 AM
Tags
hpop, oil, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
