engine swap 4.9efi to 302 carb
I would stick to a 300 six or go with a 351w but....if you do the swap get the whole other truck with the 302. You need motor mounts for the frame, Y-pipe, flywheel for the 302. The radiator because the hoses are on the wrong side and all the wires off the 302, coil and stuff
Good luck with your swap I hope I helped some
dwhawkins89
03-21-2015 06:39 PM
ftrk66
05-06-2011 07:03 PM
