What are the dimensions of a Ranger chassis - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 11-03-2007, 07:28 AM
Perfessor Perfessor is offline
Perfessor is starting off with a positive reputation.
I found that a Ranger and a '34 Ford coupe have the same wheelbase. There are fiberglass bodies available and I'm thinking of getting an older Ranger and putting a coupe body on it. Where can I find a diagram of a Ranger chassis or the dimensions written out?
Old 11-03-2007, 12:08 PM
ranger pat's Avatar
ranger pat ranger pat is offline
ranger pat has a good reputation on FTE.ranger pat has a good reputation on FTE.
Rangers come in three wheel bases. Track width and wheel base vary from year to year. What is the approximate wheel base and track width of the body you are looking at?
Old 11-04-2007, 05:09 AM
The frame was 44" wide at the rear and 25.75" at the front. The '34 coupe had a 112" wheelbase. I saw the regular cab short bed Ranger looked promising.
Old 11-04-2007, 11:28 AM
tbolt 460's Avatar
tbolt 460 tbolt 460 is offline
tbolt 460 is starting off with a positive reputation.
107.9 in
113.9 in
125 in
Old 11-05-2007, 07:35 AM
Does anyone know the frame dimensions? Those are critical.
Old 11-05-2007, 11:34 AM
tbolt 460's Avatar
go to a junkyard
Old 11-05-2007, 12:11 PM
ranger pat's Avatar
Here are some 1998-2002 Short wheel base regular cab dimensions.
Wheel base 111.6"
Front tread width 58.6" measured an centerline of tread
Rear tread width 57.3"
Rear frame width 32.8" outside to outside. Inside to inside 27.8"
Frame kicks up in the front and rear quite a bit. About 22" behind centerline of front wheel, the frame is flat for about 32 inches. The top of the frame kicks up in front about 9" at the front wheel and the top of the frame kicks up about 10.5" at the rear wheel. About 22" behind the front wheel and continuing rearward the frame is straight as you look down on it in a plan view.
Old 11-05-2007, 12:16 PM
Quote:
Wheel base 111.6"
Thanks! It's just what I was after.
Old 11-05-2007, 05:18 PM
5.0B2's Avatar
5.0B2 5.0B2 is offline
5.0B2 is starting off with a positive reputation.
Have a ball. One of our local builders put a 34 pickup on a ranger chassis with a turbo thunderbird 2.3 liter. Really nice combination
Old 11-06-2007, 05:47 AM
Quote:
By the way, do you know the front frame width?
Old 11-06-2007, 08:43 AM
ranger pat's Avatar
I have a few old FORD BODY BUILDERS books in my library of shop manuals and owners guides.
Old 11-06-2007, 05:47 PM
5.0B2's Avatar
30" outside to outside
Old 11-06-2007, 05:52 PM
5.0B2's Avatar
that's for an '84 - my '97 is 31 1/2
Old 11-05-2008, 07:43 AM
63Tennessee 63Tennessee is offline
63Tennessee is starting off with a positive reputation.
hey t-bolt460, was wondering which years and bed style of ranger had the 113.9 wheelbase you mentioned here? i have a 63 ford stepside im looking to do something with. it has a 114" wheelbase and about a 60" track so far this ranger is the closest thing ive found...please let me know if you can.......thanks
Old 11-05-2008, 07:54 AM
tbolt 460's Avatar
107.9 in (short bed reg cab)
113.9 in (long bed reg cab)
125 in (short bed xtra cab)
http://www.edmunds.com/insideline/do...rticleId=49541
1961-63 unibody chassis dimensions Pireaux 1961 - 1966 F-100 & Larger F-Series Trucks 4 08-24-2016 08:21 AM
1972 F-250 Chassis dimensions dinosaur62 1967 - 1972 F-100 & Larger F-Series Trucks 5 07-02-2011 02:10 PM
New here, a few pics of my F-100 slow90coupe 1973 - 1979 F-100 & Larger F-Series Trucks 26 03-21-2011 06:51 PM
3.8 Super Coupe swap IATSE44 Ranger & B-Series 27 02-05-2007 09:30 PM
Chassis dimensions? mpatience 1947 and Older Ford Trucks 1 07-24-2005 07:01 AM
Tags
2001, 2005, 34, 88, bed, chassi, chassis, demensions, dimensions, explorer, ford, frame, on, ranger, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
