5.4 for cobra
5.4 for cobra
A cry for help I recently came across a 96 cobra with a blown up 4.6 and a friend has a wrecked 04 f150 with a 5.4 in it tha still runs fine with low milage. My question is will the doc heads off the 4.6 fit the 5.4 and if so which head gaskets should be used the 4.6 or 5.4. Finally the last brain teaser is does the ballencing on the lower rotating assembly of the 4.6 and 5.4 share the same characteristics as far as dampener and flywheel weight and if so will the flywheel off the 4.6 fit the 5.4. thanks
You can use a Navigator intake which works well on a stock engine. They just did a intake comparison on a DOHC 5.4L in the last Muscle Mustang and Fast Ford mag.
Actually, if you can get a 2000 Cobra R intake, it will be closest to fitting under the hood and have the right powerband for a Mustang.
best intake for the 5.4, especially high revving 5.4s or forced induction projects, sullivan... hands down
http://www.karkraft.com/new_page_1.htm
You can try these guys. They tend to have good pricing on most of the stuff that you would need.
