Straight6 w/1bbl question
Hello, nice to meet ya, I'm new here. I will go introduce myself properly in a moment... but my question is more important right now.
I have a 1979 Straight 6 with a 1bbl carb and it idles like crap, it puffs out black smoke... running rich... but under acceleration and at speed it runs ok... ideas?
thanks in advance!
-grumman
I'll go introduce myself now
thanks in advance!
-grumman
Hello, Grumman,
Mickman here, also new to the forum.
I would try to adjust the jet for the idle circuit; as I recall, there is an idle circuit and a high speed circuit in the carb. It's usually the air-fuel mixture screw on the side of the carb.
I have a '78 F-100 that has the same motor and carb, but it's got so many probs that I just consider myself lucky when I can fire it up and drive it.
Good luck.
Good luck.
I had replaced the needle and seat along with gaskets (cause it leaked fuel). everything looked ok, so I didn't do a complete rebuild, but it runs really bad... I've also posted this in the 300 I-6 forum... sorry for double posting, I didn't realize there was an appropriate area.
I tried adjusting the mixture screw while at "operating temperature" and it doesn't make a lick of difference.
I'm guessing the suggestion will be... rebuild it COMPLETELY or replace it.?
thanks for your replies!
heres the link to the other post so we can move to the right spot... https://www.ford-trucks.com/forums/6...-6-newbie.html
Before jumping the gun and buying a new carb, put a vacuum gauge on it and look for a vacuum leak first! I would also grab the carb and try to shake it. The things are famous for becoming loose and idleing like crap. If your carb is loose, you'll need to take it off to tighten the screws because they can only be accessed from the bottom of the carb!
I appreciate the replies... I don't have vacuum guage so that is going to have to change soon.
the carb is tight, so no luck there.
I've replaced the gaskets and it doesn't leak anymore.
I adjusted the float acording to the directions that came with the kit... hopefully I did it correctly... It said that there should be an inch and a quarter droop... this is setting it dry... sound right? they even provided a nifty little ruler to use.
I noticed the exhaust manifold is cracked... how can this affect the way it runs... other than sounding like it has an exhaust leak?
thanks for your help!
PS I'm going to finish this in the other post, so as not to **** anyone off. thanks again for everyones input! you've been most helpfull!
From my experiences when you buy a "rebuilt" carb for one of these trucks what it means is some company (maybe) put throttle shaft bushings in and then put a gasket kit in the carb without setting anything and ship them to the next store.
I went through three "remanufactured" carbs in as many days because all the ones I kept getting actually ran worse than the one i was replacing.
Finally on the 4th one before i even installed it on the truck I tore it down and set everything to spec. When I got it the float would hit the bottom of the float bowl and would touch the top of the airhorn before shutting fuel off (as in had i installed it, it never would have shut off the flow). the idle screw was also only in about 1/2 of a turn (no biggie), and the metering rod was run all the way down into the jet (as in it wouldn't have run over an idle had i installed it as is).
YMMV.
Justin
YMMV.
Justin
thanks for all the input guys... I've looked into it a little more and found that it could possibley be a vacuum problem as well... this is an old bread truck was in service for a long time and no telling what happend to it after they pulled it out of service... so, it seems I've got my work cut out for me. I intend to replace the exhaust manifold and rebuild the carb... see what happens and go from there... I'll keep y'all up to date as I go along! any other thoughts till then are welcomed and appreciated!
Oh, by the way... would any of you happen to know where I can find a diagram for the vacuum set up? I have no idea where everything is supposed to go so I can't even tell if its hooked up correctly now... thanks!
