How much HP you guys guess?
I put a 528 460 based stoker in my 93 lightning it has these goodies, 4.3 stroke, 6.8 rod 4.420 bore, singleplane edlebrock torquer intake,solide flat tapet cam with 660 668 lift and 256 260 duration at .050 on a 111 lobe sep. also ported procomp alum heads with 2.19 and 1.72 valves. will be probly running a 850 mighty demon carb and 2" header if I can find them. will be dynoing to break in cam and engine within the next 2 week will post what happens. I hope for 600 hp and 600 torque and to burn some tires once installed.
