Help! My Truck won't start
Greetings!
I cleaned the battery terminals on my 7.3 liter
Excursion this morning because I was getting a few false alarms in the middle of the night. I diagnosed the trouble and thought it might be current loss trigering the current draw module. Anyway, when I reconnected the batteries, the anti-theft light kept flashing. I tried three differnt keys, all programed, but the truck will not start. When I turn the key I hear a buzzing under the hood, then the theft light rapidly flashes. My Batteries are reading 18.5 on a voltmeter and I changed my cps. Still, the light flashes. Any help that you guys can render will be most appreciated.
Thanks!
KennyG
Thanks!
KennyG
well, a couple things come to mind...
the buzzing noise... any idea what part of the engine compartment it's coming from? (bad ground at, or possible bad starter relay?)
actually, you could do a voltage drop test across any and all of the cables and cable connections... no more than .2v drop, otherwise you've got a bad cable or a bad connection...
bad (notice I didn't say "blown") fuse?
starter enable relay take a poopie?
Anti-theft module went sToOPid when you had the batteries disconnected?
Originally Posted by KennyG228
The alarm is an add on module, the crimeguard al100 I think. Now the batteries are low, but the theft light still flashes.
Thanks for the replies. I'm standing by.
KennyG228
KennyG228
recharge the batteries and check your voltage drops.
while you're at it, try disconnecting power to the alarm and see what happens
on
Greetings!
My Batteries are reading 18.5 on a voltmeter and I changed my cps. Still, the light flashes. Any help that you guys can render will be most appreciated. Thanks! KennyG
I would say your volt meter is wrong.. I don't think you can get 18.5 volts out of a 12 volt battery..
The most you can get is around 14.5 volts and that is with the engine running.
KennyG228
KennyG228
P.S. If you ever over near Millbrook/Prattville look me up.
David Vox Mullen
Escape & Escape Hybrid
03-08-2024 07:45 AM
bitco
1997-2006 Expedition & Navigator
07-08-2013 07:32 PM
RhondaBruce
1983 - 2012 Ranger & B-Series
03-14-2011 09:19 AM
