Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-02-2007, 03:28 PM
Brent M. is starting off with a positive reputation.
Question oil leak!
my 01 escape 4x4 3.0 has an oil leak which seems to be coming from around the drivers side drive axle....it only leaks noticeably when you have driven the vehicle at highway speeds for a sustained period of time...other wise it is rarely noticeable(on my driveway for example)....any info/ ideas on what it is and how to fix would be appreciated....thanks for any input.....Brent M
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 11-04-2007, 09:40 PM
2fords2 is starting off with a positive reputation.
When my '01 4x2 Escape did that it, turned out to be the a/c compressor. Not engine oil. In my case the a/c belt pulley was moist and there was a noticeable line of oil on the radiator and the driver's side plastic guard under the compressor pulley. Otherwise, there are a number of engine seals on the driver's side. The power steering hoses and reservoir is another potential culprit. Hard to diagnose w/o visually inspecting it.
It probably does not stain your driveway because whatever the leaking fluid is, it's blown behind the engine on the underside of the vehicle as you drive down the highway.
Either way, these sort of repairs are all big $$$'s. The a/c was $1,000. When the oil pan gasket and valve cover gaskets leaked a couple of years ago, it was over $400 as I recall. These are local Ford dealer prices, not an independent shop which might be a little less costly.
  #3 (permalink)
Old 11-05-2007, 01:59 AM
thanks for the input...i crawled around under there today,and acually,i think it's either tranny fluid,or power steering fluid,not engine oil....it just looked like the leak was coming from the drive axle,but now,i don't think it is...again,it looks like it is either tranny or power steering oil(reddish in color)....i'll have to jack it up and have a better look at where it is coming from.....but for some reason it definately leaks worse on sustained,longer,highway speed type trips!
  #4 (permalink)
Old 11-05-2007, 11:47 PM
aquanaut20's Avatar
aquanaut20 is starting off with a positive reputation.
Check the fluid levels and see which one is low. Report back....
  #5 (permalink)
Old 11-06-2007, 02:13 PM
looks like it is tranny...i just changed the fluid out a while ago and it is has gone down....Brent
  #6 (permalink)
Old 11-06-2007, 04:45 PM
aquanaut20's Avatar
best not to drive until you locate the source of the leak, repair and fill.
Either power wash or wipe down, so you can isolate, oil tends to blow around at road speed.
  #7 (permalink)
Old 11-06-2007, 08:32 PM
thanks for the input...next days off i am going to investigate further.......Brent M
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
