Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-02-2007, 07:26 AM
David in Boerne, TX David in Boerne, TX is offline
Garage is empty, add now
David in Boerne, TX is starting off with a positive reputation.
Engine verification
New to the board. Got a 1962 Ranchero with a six. Need to rebuild the carb or get a new one. I suspect the engine is not the 144 that was original to the truck. How can I determine which six cylinder engine (144, 170, 200) is in the truck? Thanks in advance.
  #2 (permalink)
Old 11-10-2007, 07:35 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Welcome to FTE
1962 could be either a 144 or a 170. Falcons didn't come with 200's till 1964. A popular engine swap is dumping the anemic oil burning 144/170 and swapping in a 200 which is a faaar better engine (7 main brgs as opposed to 4) then the terrible two it finally replaced. The three engines exterior appearance is identical. 1960/66 engines blocks/heads were painted all black, with a different color for the valve cover. This is the system Ford used back then to quickly ID what engine it had. Question: what color is the valve cover? What color is the rest of the engine?
Carb: Is there a triangular shaped Ford carb ID tag anywhere? What type of carb: Autolite, Motorcraft or Holley? Holley would have been the original one. If it's a Holley, look on the body of the carb for an ID number similar to: A0D0AC, then take that number to NAPA, who'll fix you up with a kit or a rebuilt carb. If you find that ID tag, list it, and I can give you the Ford and/or Motorcraft part number for the kit.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #3 (permalink)
Old 11-10-2007, 11:03 AM
Roger Carter's Avatar
Roger Carter Roger Carter is offline
Roger Carter is starting off with a positive reputation.
The 144 and the 170 engines have 3 freeze plugs in the passenger side of the block, visible under the exhaust manifold. The 200 has 5 freeze plugs. It is difficult to get much more specific without getting into the engine and confirming the bore and stroke.
Good luck.
Roger Carter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
