85 ranger 2.8L carb problem - Ford Truck Enthusiasts Forums
Old 11-01-2007, 06:57 PM
oneofakind97's Avatar
oneofakind97 oneofakind97 is offline
oneofakind97 is starting off with a positive reputation.
hey guys. i recently got an 85 ranger in real nice shape for cheap. one of my big problems is that the motor always wants to stall out right when i start to take off at low rpms. since the truck is stick, its a problem through all the gears, and its getting really annoying. my mechanic narrowed it down to a "choke pulloff". i work at a napa and i got the part for 12 bucks. now all i need to know is how to go about installing it. i was wondering if theres a walkthrough somewhere that i can follow. i was given some rough verbal directions, but i like to look at some pictures and stuff to see if im doing it right. especially if its new to me. can anyone help me out? thanks alot.
Old 11-02-2007, 09:31 AM
TigerDan's Avatar
TigerDan TigerDan is offline
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
I'm not all that familiar with that particular one, but generally it's a pretty easy installation. It's a simple vacuum dashpot that mounts to the carb with two screws on its bracket. The linkage is held into a slot that allows it to slide with a simple circlip, hopefully your new pulloff comes with that circlip as it's very easy to lose the little bugger when you take it off. Then there's a vacuum hose to tkae off and reconnect, and that's really about all there is to it.
Here's a link to a PDF file with some explicit instructions and pics. Scroll down to page 4 and 5 for some detailed pics of the pulloff and its removal:
http://www.kansas4xford.com/Tech/2150%20rebuild.pdf
Old 11-06-2007, 01:51 PM
Canadianice Canadianice is offline
Canadianice is starting off with a positive reputation.
I have an 84 Bronco II with the exact same Motor. It takes about 15 minutes to do this repair. First off remove the air cleaner from atop the Carburetor. Next find the choke pulloff attached to the carburetor, It will be on the back left if you are facing the front of the truck. The hard part is trying to get a screwdriver or socket onto the screws that hold the pulloff to the carburetor since there is no easy way to see them. Just do it by feeling and take your time because the thing thats a pain is to drop the screws some where in the motor compartment. Once you have got those screws undone remove the vacuum line from the old choke pulloff and then install the new one in the reverse order. Now if you complete this and you still have this problem of stalling at low rpm it may be the carburetors accelerator pump.
All the choke pulloff really does is open the choke to a specified opening while the truck is cold. This allows the motor to suck in air from around the choke plate while the truck is cold. Since the pulloff is only opening the choke plate a certain amount this will cause the fuel mixture to be richer which is need on cold engine start up. Now as the motor warms up the the choke is gradually opened by the choke cap by an electrical pulse signal. Basically a coil of wire inside the cap is heated by an electrical current causing the choke to open as the wire is heated greater and greater.
So what Im trying to say through all that is that the choke pulloff really only matters when the truck is first started. Once it is at operating temperature and the choke has been fully opened by the choke cap the pulloff no longer matters. So if your truck is stalling after being driven for a while it wont be the choke pull off.
I had a very similar problem with my truck for about a year and only about 6 months ago found the problem. It had to do with the accelerator pump. So anyway my hand is getting tired from typing, so if the pulloff does not fix your problem. give me a shout back here and I can help you out.
Old 11-07-2007, 03:59 PM
hey guys, thanks for both of the responses. i used info from both when i put the choke pull off on. it wasnt hard at all, but i still ahve the same problem. but now the truck starts up first time instead of 2nd or 3rd try.
canadianice, i bought the accelerator pump today at work (i work at a NAPA) and it cost me 8 bucks. how do i go about doing this repair? i dont recall seeing anything about it in tigerdan's link, then again, i didnt read all the way through it. thanks for the advice guys.
Old 11-07-2007, 06:15 PM
It is in there about half way down the article. its an amazing article i would really suggest reading it. It is really simple to install the accelerator pump, first take off the air cleaner once again. Then at the front of the carb. you will see the accelerator pump rod that extends out from the where the throttle linkage attaches to the carb.. Follow the linkage back to the front of the carb. where it will attach to a swivel arm that activates the accelerator pump. You will see 4 screws holding the housing to the accelerator pump to the main body of the carb.. Remove these but be careful as fuel will leak out when you take the housing off, just make sure to have a few rags handy to catch it. At this point the accelerator pump will be right here and you should with no big deal be able to replace it and reinstall everything.
While you have the accelerator pump apart make sure the little red diaphragm that is a one way valve is in great shape, if not I recommend replacing it as well. to do that read through that link that was provided for you and it will making visualizing this very easy. You will need to remove the top of the carb. housing. there are six screws that need to be removed to remove it. Then once that is off you will be able to see inside the Carb. where the float is located. Remove the float by reading the instructions in that link. Once the float is removed then you can see where that red diaphragm end enters the fuel bowl of the carb. to allow fuel into the accelerator pump. This will enable you to, if needed, to pull the the end of the new diaphragm through into the fuel bowl.
Now when I was having this problem just like you it was also another problem besides the accelerator pump. after you remove the accelerator pump take a look at the little hole right above the round red diaphragm. The hole should be very small maybe big enough to get a small needle through. what this hole does is allow a certain amount of fuel to be pushed back into the fuel bowl instead of down the hole underneath the red diaphragm that shoots the fuel into the carb to allow you to accelerate. So if the hole is to big it will allow to much fuel to go back into the fuel bowl and not squirt it into the fuel air mixture. this is why i was getting the stalling on acceleration issue.
If you assemble the carb with the new parts and it still does the stalling thing this little top hole is you problem, it will need to be made smaller by plugging it more somehow. That I must leave to you, because the reason my my trucks return hole was to big is because the place I purchased the remanufactured carb from were idiots and had given me the wrong carb body with a bigger hole. After a year of intense investigation i solved this problem by going to an auto wrecked and getting a junker carb off a bronco II and rebuilding the right body with the new parts of the remanufactured carb.
Good luck, shoot me with questions if you have them.
Old 11-08-2007, 04:03 PM
thanks man, youre a savior. im gonna go into teh garage and get to work right after i eat dinner. ill post up and let you know how things turn out.
Old 11-08-2007, 06:17 PM
alright, just wrapped everything up. it seems to have fixed the problem, or atleast made it better. the real test is going to be tomorrow morning when its 34 degrees out and the truck sat all night. hopefully im in the clear.
the repair was really easy too. it would have taken about 20 minutes if i didnt have to scrape the old gasket off of the housing. once again, the biggest challenge was finding enough space for tools.
thanks again for your help.
Old 11-09-2007, 12:51 AM
good stuff, anytime, the only reason I have been able to fix my truck is because of this whole forum, so anytime I can pay back how they have helped I do.
Not so new to group johnro6659 New Member Introductions 1 05-02-2016 02:54 PM
clutch problems Diesel wyatt Ranger & B-Series 2 05-11-2015 09:51 PM
'85 F250 Clutch Problem TiBones Clutch, Transmission, Differential, Axle & Transfer Case 3 05-20-2012 07:12 PM
Can E85 damage engine if never used in past? bluegroove Ranger & B-Series 15 03-05-2011 12:34 PM
1985 Ford Ranger parts wanted Codys 85 Ranger Mid-West Region 2 06-06-2007 05:26 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
28, 40, 85, 85ranger, bronco, carberator, carburetor, change, choke, ford, ii, problems, pull, ranger, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
