Cruise control recall - Ford Truck Enthusiasts Forums
Old 11-01-2007, 05:09 PM
OleGrouch's Avatar
OleGrouch OleGrouch is offline
OleGrouch is starting off with a positive reputation.
Got the recall on the 93 lincoln taken care of but now I am trying to find out for sure about the same recall on the 93 F-53 chassis under the 94 Bounder motorhome, can anyone help this, OleGrouch
Old 11-01-2007, 05:16 PM
Skandocious's Avatar
Skandocious Skandocious is offline
Skandocious is gaining momentum as a positive member of FTE.Skandocious is gaining momentum as a positive member of FTE.
Go to a Ford dealership. They can look up your truck by VIN# and see which recalls have and haven't been taken care of.
Old 11-01-2007, 05:17 PM
Virto's Avatar
Virto Virto is offline
Virto has a good reputation on FTE.Virto has a good reputation on FTE.Virto has a good reputation on FTE.
I need to get it taken care of on my 93 as well. I checked for open recalls and it hasn't been completed yet.
Have to find a dealer up here, the Ford places have started to disappear and the import dealers are moving in.
Old 11-01-2007, 05:24 PM
OleGrouch's Avatar
My local Ford dealer cannot access the large truck screen on his computer, I have some info from the Bounder web-site but need more. OleGrouch
Old 11-01-2007, 05:32 PM
I would think that the same recall applies, it applies to almost every Ford cruise control in these era of vehicles. All they do is install an inline fuse on the cruise control disable switch. Apparently the brake fluid was shorting out the switch and causing underhood fires. If you have cruise control, and it looks like the one on your lincoln, and there is NO FUSE on the disable switch near the fluid reservoir, then you probably need to get it taken care.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
