92 inline 5 speed with 2.43 rear end gears?
OK, I thought it was a little high geared when I got it. Was going to try to put some bigger wheels on it, but now I'm afraid because any taller tires will make the ratio even worse. 2.43? I was surprised. The code for the differential is 12 which I looked up.
Anybody familiar with this ratio and what do you think...should I get it changed right away. I mean, I'd like first to be lower and fifth I have yet to go fast enough anywhere for it to actual be any use.
Thanks.
Thanks.
Dang it...I meant 2.73! That's right...still seems way tall...jas88: I don't know what trans you got, but mine is in the low rpm range at 55 in fourth...and we don't have super highways around here...I can't see the little six banger hauling me at 80 or so...
sorry, I was still sleepy when I said 2.43...lame. Is there some kind of calculator to figure what the best gears for the rear end would be? Cause 2.73 aint it!
thanks.
thanks.
