Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-01-2007, 01:10 PM
Finnzo's Avatar
Finnzo is starting off with a positive reputation.
Transfer case spotter's guide?
Hi guys! I got a quick one I couldn't pull up from a search of the postings -- my owner's manual tells me I gotta 1345 or 1356 peanut. How can I tell which one? And which is the more desirable unit?
Thanks!
--Finn
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 11-01-2007, 07:58 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.
1345 was first, C6 and T 19 trucks had them.
1356 was used mostly in the overdrive equipped trucks.
No real advantage to either one over the other in my book.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #3 (permalink)
Old 11-01-2007, 08:33 PM
Finnzo's Avatar
Right on -- mine must be a 1356 then -- what's the diff between 'em?
Thanks!
--Finn (90 "Fordbinder" F250 XLT/L std cab, 4x4, ZF-5, 4.10s, 444 "IH Inside"
Corvallis/Albany, Ore.
  #4 (permalink)
Old 11-01-2007, 10:51 PM
After I split my 1345 I asked my driveline guy if I should upgrade to the 1356.
His answer was it was not worth the swap to change.
Since my 1345 was laying on the floor in two pieces when he said that, I just dismissed the thought and never went any farther with the discussion.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
