Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-31-2007, 11:01 PM
kman101 is starting off with a positive reputation.
Catalytic Converters.
I read on another thread that a cat may reduce the gas mileage of cars. i have a bronco 2 with the stock engine and tranny. i get about 16 to 17 mpg. and it feels real slugish sometimes. i guess my question is that if its legal to gut or not have a cat on my bronco. Thanks.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 10-31-2007, 11:20 PM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
Your problems could be a number of things, including a partially clogged cat.
Do you have smog inspections for your vehicle in your state? If so, you will not pass w/o a cat.
It's not legal to remove or disable the cat. But unless you have inspections no one is going to know.
There are some ways to determine if the cat is clogged by measuring pressure in the exhaust at the oxygen sensor, perhaps an engine vacuum test, maybe a couple of others. If you can disconnect it you can visually inspect it and see how your rig runs without it.
But, there are a number of things that cause performance to go downhill and high miles/age are part of it.
Have you done a compression test? Check for vacuum leaks? Basic stuff along with checking the cat.
Good luck.
  #3 (permalink)
Old 11-01-2007, 12:20 AM
rebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to behold
That works with vehicles with an O2 after the cat, a BII has a single one before the cat.
The automatics can be sluggish, 16-18 mpg is normal with the automatic. You can adjust the cables with lead weights or zip ties. I posted about that a few years ago if you do a search.
  #4 (permalink)
Old 11-01-2007, 10:45 PM
all sounds good. and i took the cat off it ran much better. i LOVE 2ND GEAR (i have a 5 speed). i put a pipe in for now. i got a universal cat cuz i dont need to pass somg tests. i dont know about mpg yet but i know now it really moves. thanks guys i really appreciate it.
  #5 (permalink)
Old 11-02-2007, 12:27 AM
Wouldn't the before the cat plug be where you'd find high pressure vs. what's coming out the pipe?
Anyway, it sounds like it was a clogged/melted cat.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
