300 I6 Valve Adjustment - Ford Truck Enthusiasts Forums
Old 02-11-2002, 12:49 PM
DrkPhanstm DrkPhanstm is offline
DrkPhanstm is starting off with a positive reputation.
Old 08-22-2002, 10:19 PM
fish462 fish462 is offline
fish462 is starting off with a positive reputation.
I have what I believe to be valve train noise coming from my 95 F-150 with the 300 I6. The truck has 100,000 on the clock, should the valves need adjusting at this point? The Chilton's manual contains the procedure but no information on the interval at which the valves should be adjusted.
Old 08-23-2002, 09:46 AM
Stephens Stephens is offline
Stephens is starting off with a positive reputation.
Good news. The 300 has hydraulic lifters and there's not valve backlash or tappet adjustment. They adjust automatically. The Ford V-8s use hydraulic lifters too. If you're hearing ticking noise, it not something that can be adjusted out.
Old 09-04-2002, 09:42 PM
I talked with a Ford mechanic and an ex-owner of a Ford dealership. They both listened to the truck and said "They all sound like that". Does any one else's late model 300 I6 sound like valves are rattling around (it isn't really a tick)? I had a 70 F-100 with a 240 which sounded like that but it was 30 years old on the original engine. I was told that noise was "piston slop". I don't remember for sure if my 93 made the same noise; if it did, it was to a lesser extent.
The oil pressure is good and the engine runs strong, am I concerned about nothing? I haven't pulled the serpentine belt and ran the engine, but the noise doesn't appear to be coming from an accessory. Could the throw-out bearing make this noise?
Old 09-04-2002, 09:50 PM
91paint pealer 91paint pealer is offline
91paint pealer is starting off with a positive reputation.
My 91 300 has 202,000 and i experience the same tapping noise seemingly from the #3 cyl. I was also told that Ford engines tend to do that after a while. I am also interested in solving this problem. Will i need head work or just an intense cleaning?
Old 09-05-2002, 09:14 AM
I know what you mean, mine gets a ticking sometimes that sounds like some serious metal wear going on. And when I 1st crank it and after reving, as the RPMS slow down, the piston knock sounds like a diesel motor. Its been doing all of that for over 150,000 miles and its still going. Slick 50 quiets everything down really well until you drain it out with an oil change. Here's something funny, my old neighbor was a 18 truck wheeler driver, had his own rig. He always thought my truck was diesel, because it sounded like his big rig. He borrowed my truck for some reason and tried to gas it up, but didn't because the diesel nozzle wouldn't fit or maybe he saw the unleaded gas sticker on the gas door, I can't remember which. It confused him so he held off.
Old 09-05-2002, 09:16 AM
Should have mentioned, I'm sure we all could use a new set of lifters, that would help.
Old 09-05-2002, 04:57 PM
gdavis2265's Avatar
gdavis2265 gdavis2265 is offline
gdavis2265 is starting off with a positive reputation.
just installed new cam and lifters- the valvetrain is a bit noisy- can hear all the rocker arms from the cab- not too bad, just sounds a bit louder than normal
Old 09-05-2002, 06:54 PM
RoadRash RoadRash is offline
RoadRash is starting off with a positive reputation.
My 300 in my 94 sounds like a diesel on start up. I found that more freqent oil changes were needed, as soon as I started hearing the clatter on a regular basis, I changed the oil. I end up doing a oil change every 2 months on average and filter every second time. So far It has kept the engine in check. I use 5w30 in summer and 10w30 in winter.
First
On
Race
Day
Old 09-05-2002, 09:06 PM
The diesel noise upon start-up is the lifters. Replace your oil filter with an FL-1a from Motorcraft and the noise should go away. The Motorcraft oil filters have a check valve which keeps all the oil from the lifter valley from draining back through the filter into the pan. There is also a kit you can buy from Ford, but the oil filter change is much cheaper and easier.
My noise comes on about 1 minute after start-up, right when the idle settles in and it really isn't a tick, it is more of a knock.
Old 09-05-2002, 11:17 PM
optikal illushun's Avatar
optikal illushun optikal illushun is offline
optikal illushun is gaining momentum as a positive member of FTE.
my 93 has a slight tick to it when its idling. it doesnt sound like anything important but i was told they all tick...funny thing is my dads 95 doesnt tick, it has a whistling noise to it ever since he bought it new. i dont notice any performace loss and the oil doesnt show any signs of wear other than normal, the oil is nice n black when i change it no metal and it doesnt burn any so im not worried about it. althought mine has 77,000+ original miles on it so its not even broken in yet but could that slight ticking lead to problems in the future?
Old 09-19-2002, 08:39 AM
turbogus's Avatar
turbogus turbogus is offline
turbogus is starting off with a positive reputation.
I seem to have the same if not similar problem in my newly rebuilt motor from Evergreen Engines in Spokane. However my rockers emit a squeaking noise sounding very much like a bad belt. Over any over I've tightened the rockers little by little (1/8 to 1/4 turn) over the past few months and this'll take care of it for about a week.... but then the squeak continues. I'm using the factory locknuts on the rocker studs and there's no apparent stud pulling. (If there's sufficient clearance I'm gonna try a straightedge along the tops of the studs next time). Sure is frustrating though. I'm used to once I fix something, by thunder, it stays fixed. Any thoughts on this?
Old 09-19-2002, 09:32 AM
Try brand new locknuts.
Old 09-19-2002, 09:51 PM
Quality 1 Quality 1 is offline
Quality 1 is starting off with a positive reputation.
Put a quart of Rislone in and they will quiet right down. I use a quart on each oil change and the tappet noise is gone. Engine now has 187,000 miles smooth, quiet, power.
Old 09-25-2002, 03:52 PM
65inline6 65inline6 is offline
65inline6 is starting off with a positive reputation.
Post 300 I6 Valve Adjustment
There's still something missing! Look at your rocker arms. With a cooled engine, move each rocker by hand. it shouldn't move more than 1 millimeter on each side, but it should move. My 240 did that. Hydraulic cams do have a little maintance. Every now and then they do need adjustment. Never heard of any rocker arm that adjusts itself. Thicker oil helps a little as well (but with winter coming lighter would be a little better).
BTW, Mechanical lifters are the ones you adjust.......ALOT
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 03:27 PM
ooops Aerostar 5 01-14-2015 03:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 06:14 AM
delete 97puller Ford Truck Parts for Sale 15 04-08-2014 04:53 PM
test jr105 Testing..... 0 04-04-2014 08:10 AM
Tags
300, 300i6, ajustment, bad, diesel, ford, hydraulic, i6, idle, lifter, lifters, noise, remove, sounds, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
