11-01-2007, 12:25 AM
Fordfury,
Welcome to FTE and the IDI diesel forum.
Did Ford install the motor?
Sounds like something did not get installed correctly.
I would be calling whoever did the install.
And I would not try to start or drive it till you figure out what is wrong, sounds like it must be inside the bell housing.
Clutch fork out of place, bolt backing out or something that did not get removed like a wrench.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
