Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Canadian National Chapter > British Columbia
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
British Columbia British Columbia
Join Chapter, Leader: Zip
  #1 (permalink)
Old 10-31-2007, 05:46 PM
DeezDay DeezDay is offline
Garage is empty, add now
DeezDay is starting off with a positive reputation.
4x4 issues
anyone have any ideas what could be wrong with my 4X4, 93 ranger manual hubs, push button 4X4 nothing happens, push button and no lights come on, when i take the switch out and use my test light there is power getting to the switch i have no idea. Has anyone ever had this problem or have any ideas.
thanks
  #2 (permalink)
Old 10-31-2007, 06:47 PM
preppypyro's Avatar
preppypyro preppypyro is offline
Posting Legend
2003 Ford F-250
preppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud of
I would check the ranger, or some of the drivetrain forums man. There you can get alot more specialized help then in here!
__________________
$Sheldon$
2003 F-250 supercab shortbox 4x4 lariat
~Everythings legal man as long as ya dont get caught~
A good fist fight never hurts anyone... except my opponent.
  #3 (permalink)
Old 10-31-2007, 10:20 PM
Digger6 Digger6 is offline
Digger6 is starting off with a positive reputation.
I would say it would be the actuator on the trasfer case, the push button chevys were famous for failling
  #4 (permalink)
Old 11-01-2007, 10:17 PM
Bandit-1 Bandit-1 is offline
Bandit-1 is starting off with a positive reputation.
you could try testing the switch or use a jumper wire to bypass the switch
  #5 (permalink)
Old 11-02-2007, 11:41 AM
how to use jumper wire
hello, bandit i am just wondering how i would bypass the switch or use a jumper wire any ideas. and thanks alot for everyones help.
  #6 (permalink)
Old 11-03-2007, 08:32 AM
preppypyro's Avatar
Posting Legend
2003 Ford F-250
When you press the button can you hear anything happening down below?
__________________
$Sheldon$
  #7 (permalink)
Old 11-04-2007, 10:54 AM
you would have to figure out witch wire the switch gives power to then use a peice of wire a couple inchs long with some aligator clips on the end of something.
  #8 (permalink)
Old 11-09-2007, 10:32 AM
preppypyro's Avatar
Posting Legend
2003 Ford F-250
Having any luck fixing it?
__________________
$Sheldon$
  #9 (permalink)
Old 11-15-2007, 12:12 AM
R031Kona's Avatar
R031Kona R031Kona is offline
R031Kona is gaining momentum as a positive member of FTE.
the fix
I just fixed my 91 Ranger transfer case with a 1 /12 work and some elbow grease and 5/16's fuel line. The link http://www.ford-trucks.com/forums/sh...d.php?t=123542 read the whole thing first though and it doesn't hurt to google it and read more sources.
  #10 (permalink)
Old 11-15-2007, 09:49 AM
preppypyro's Avatar
Posting Legend
2003 Ford F-250
That is an excellent link r031 thanks for posting it!
__________________
$Sheldon$
  #11 (permalink)
Old 11-15-2007, 09:28 PM
R031Kona's Avatar
It really does help to have it on a bench unless you have a helper or three hands IF you take apart the motor itself. The brushes for the armature really are a pain , I did mine in a lube bay and proped it on the transfercase skidplate. Took me 5 try's to get the armature in place :-)
  #12 (permalink)
Old 11-18-2007, 10:26 AM
preppypyro's Avatar
Posting Legend
2003 Ford F-250
Hey 5 trys isnt that bad at all, especially when you succeed in the end.
__________________
$Sheldon$
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
