Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
New! Use your Facebook to securely log into this site, click logo to login
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-31-2007, 04:23 PM
KCGman KCGman is offline
KCGman is starting off with a positive reputation.
Installing snowplow. Any advice???
03 F350 Powerstroke
Putting on a 7.5 foot meyers plow for the winter. Is there anything I need to know that I might not be thinking about?
  #2 (permalink)
Old 10-31-2007, 04:53 PM
Redcoat Redcoat is offline
Redcoat is starting off with a positive reputation.
I too am curious. Does snowplowing place significant stress/harm on the vehicle? even for non-commercial plowing.
  #3 (permalink)
Old 10-31-2007, 05:01 PM
blackhat620's Avatar
blackhat620 blackhat620 is offline
blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.
Quote:
Originally Posted by KCGman
03 F350 Powerstroke
Does your truck have the Snow Plow package?
__________________
Courage is being scared to death---and saddling up anyway.
-John Wayne-
06 F350 CC SB 6.0 4x4, Suburban Ford (Thanks Ernie )
04 F350 CC SB 6.0 4x4, Van Bortel Ford (Thanks Jeff ) [Traded 05/2006]
  #4 (permalink)
Old 10-31-2007, 05:03 PM
Quote:
Increases stress to the transmission, drivetrain and suspension. Transmission is usually the first thing to fail.
__________________
-John Wayne-
  #5 (permalink)
Old 10-31-2007, 05:11 PM
be250 be250 is offline
be250 is starting off with a positive reputation.
hey, lee's summit i'm in independence mo. ,ihave a 250 & 450 with plows call me at 7975589 barry
  #6 (permalink)
Old 10-31-2007, 07:00 PM
Quote:
No plow package that I am aware of. Should I get something?
  #7 (permalink)
Old 10-31-2007, 07:01 PM
Quote:
Barry, I'll call you after all the trick or treaters slow down a bit.
Thanks
  #8 (permalink)
Old 10-31-2007, 07:18 PM
The Snowplow package gave max front springs to support the weight. Also CC F250/350 diesels are not rated for a plow, and niether is the SC F250.
Here is the recommended equipment per FMC:
Snowplow Installation/Minimum Required And Recommended Equipment
The Super Duty F-Series vehicles tabled below are available for snow plow usage.
Minimum Required Equipment
• Snowplow Package, includes:
—Highest Front GAWR’s (5200 lb. for F-250-350; 6000 lb. for F-450-550)
—Steering Damper
—Auxiliary Rear Springs on SRW Models With 5.4L V-8 Engine (Effective Nov. 2002)
• Plow and attaching hardware weight limits are as tabled below.
Recommended Equipment (Not Required)
• All-Terrain Tires and Roof Clearance Lights (Optional with SRW Pickup models)
Standard Equipment
• Front stabilizer bar
• Rear stabilizer bar (Standard on Chassis Cab and DRW Pickup models)
• Roof Clearance Lights (Standard on Chassis Cab and DRW Pickup models)
• Engine oil cooler, auxiliary automatic transmission oil cooler and maximum capacity engine coolant
radiator are standard
• All available axle ratios are acceptable
• Available with manual and automatic transmission. Operate automatic transmission in Overdrive gear when snowplowing
http://www.fleet.ford.com/truckbbas/...essd_03abb.pdf
__________________
-John Wayne-
  #9 (permalink)
Old 10-31-2007, 07:52 PM
pbeering's Avatar
pbeering pbeering is offline
pbeering is starting off with a positive reputation.
First of all, surf to www.letstalksnow.com
As for the truck, you may want to consider the following:
1. Timbrens for the front to help carry the weight
2. Aggressive tread pattern on the tires. (Cooper ATR are considered very good for this) (we also have Goodyear Wrangler Silent Armors on two trucks)
3. Ballast for the rear (tube sand, rock salt, steel bars, whatever.) Typically about twice the weight of the plow.
4. Winter wiper blades
5. Liability insurance for plowing
6. Spare pins, hoses, solenoids, and low-temp hydraulic fluid for the plow
7. Fluid Film to keep things lubricated and from corroding
8. Check all belts, hoses, fluids. If there is any doubt, replace it.
When plowing, be sure to bring the truck to a complete stop before changing direction. Failure to do so will eventually cost you a tranny.
Feel free to e-mail if you need anything else. Had an '03 (and have some useful spare parts) until May. Great plow truck.
  #10 (permalink)
Old 10-31-2007, 08:35 PM
Outlaw350 Outlaw350 is offline
Outlaw350 is starting off with a positive reputation.
I plow commercially. I have done it with 01,03,05, and now 08 fords. All 250's til the 08, now a 350. I ran all the trucks till about 80,000 miles with zero issues. Heavy boss 8'2" V plow, no Snow Plow Prep till this 08. I think you will be fine.
  #11 (permalink)
Old 11-01-2007, 01:07 PM
hydro_37 hydro_37 is offline
hydro_37 is starting off with a positive reputation.
First thing you should do is check out the forums at www.plowsite.com
You should definately get at least an 8' blade for your truck. I have an 8' 2" V blade on my truck and it does great. No plow pkg. My 99 was set up the same and never had any problems doing both residential and commercial. I have the V-10 engine.
__________________
2004 CC Short bed 4X4 3.73 V-10 A/T tow package heated power mirrors and a Sno-Way V plow
1993 Ranger Ext Cab 4.0 A/T 4X4 XLT (gas saver rig)
Some people are like Slinkies. Not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs
  #12 (permalink)
Old 11-01-2007, 01:10 PM
Quote:
Originally Posted by hydro_37
First thing you should do is check out the forums at www.plowstie.com
Fixed the link for you:
www.plowsite.com
__________________
-John Wayne-
  #13 (permalink)
Old 11-01-2007, 01:13 PM
Thanks blackhat.... my fingers were working faster then my brain....lol
__________________
  #14 (permalink)
Old 11-01-2007, 01:17 PM
Yeah i know the feeling, i do that far to often myself.
__________________
-John Wayne-
Tags
2006, boss, cost, direction, f250, ford, install, installing, package, plow, prep, shop, snow, snowplow, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive -
Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
