Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 04-30-2002, 08:48 AM
ckbroiler ckbroiler is offline
Garage is empty, add now
ckbroiler is starting off with a positive reputation.
Post 1997 F-150 4.6L 4X4 Oil Filter Location
I must be going crazy!!! I decided that I've been paying way too much to have my oil and oil filter changed on my '97 F-150 4.6L 4X4 truck (w/ oil and transmission cooler). So, I go ahead and buy the oil and filter, then drain the engine oil. Then I spend the next hour looking for the oil filter. I can't find it anywhere. I crawl around underneath the truck, in the engine compartment, look in every nook and cranny, but no oil filter. Finally, after it starts getting dark, I give up and refill the crankcase with fresh oil (with the old oil fitler).
Any ideas would be appreciated. I feel like an idiot.
  #2 (permalink)
Old 04-30-2002, 10:37 AM
forddy forddy is offline
forddy is starting off with a positive reputation.
  #3 (permalink)
Old 04-30-2002, 10:43 AM
BeeerMan BeeerMan is offline
BeeerMan is starting off with a positive reputation.
Ford used an oil filter relocation assembly on your truck, look behind the front bumper, drivers side, real easy to get to.
  #4 (permalink)
Old 04-30-2002, 03:18 PM
p_white p_white is offline
p_white is starting off with a positive reputation.
The oil filter is on the drivers side directly above the front differential. The filter barely fits up thru the steering linkage, but it does fit.
  #5 (permalink)
Old 04-30-2002, 05:15 PM
dabrnx dabrnx is offline
dabrnx is starting off with a positive reputation.
It should be located by the drivers side front wheel.
Tags
1997, 2002, 2003, 46, 46l, 4x4, 97, change, explorer, f150, filter, ford, location, oil, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
