10-31-2007, 12:38 PM
088 ATS turbo
Does anyone know what turbo type the ATS 088 uses? I have heard is the garret T4 (T04B), But there is precious little info in the web as to the exact model number of the turbocharger itself.
The reason I ask, is becuause in a different thread, the topic came up that a slightly damaged compressor blade could throw off the balance of the turbo, and I have noticed at shutdown, the compressor tends to start a slight wobble as it slows to a stop, so it could be loosing some energy to a misbalance. There are some nicks on the compressor wheel, and with a micrometer, I discovered that at least one blade was slightly bent.
I'm thinking it might be worth getting an overhaul kit as well as a new compressor wheel, but I don't know where to start for the model type itself.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel  Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
