1978 - 1996 Big Bronco
Plow on a Bronco
Old 10-31-2007, 08:26 AM
GLR's Avatar
GLR
GLR is online now
Plow on a Bronco
A friend of mine is picking up a 79 Bronco and is looking for some snow plow advice. Would a plow just have to be for a Bronco? How about one of a 77 F150? Thanks, George
Old 10-31-2007, 04:00 PM
rsalter66's Avatar
rsalter66
rsalter66 is offline
I dont see why not! but in my opinion , putting a plow on these just destroys the front ends, the king pins are not heavy enough for all the abuse they take, 250,s and 350's are much better suited for this with bigger pins, but if you are not doing alot of heavy plowing I'm sure it will be fine, now dont get me wrong they will do the job ! they just wear out quicker than the other's
Old 10-31-2007, 06:58 PM
aurgathor's Avatar
aurgathor
aurgathor is offline
In general, with a few exceptions, parts and attachments are interchangeable between Broncos and F150s of comparable vintage.
Your friend might also want to consider heavy duty or F250 front coils, plus a tranny cooler (if AT) for snow plowing.
Old 10-31-2007, 07:44 PM
lostin90s's Avatar
lostin90s
lostin90s is offline
I ran the 1/2 tons all time with plow had a 78 for 10 years . Just keep repacking bearings every year . As for pins No more often to replace unless you will be running on road all time . But for a drive or 2 they r fine. Get F350 2x4 front coils and air bags . Theses are great short and easy to get around.
Old 11-01-2007, 04:31 PM
hunter1897's Avatar
hunter1897
hunter1897 is offline
I just bought both a 1988 Bronco and a 1989 F150. Having worked for Ford a long while, I know that those two trucks had the same front end. I bought the truck because it had a plow on it, and I wanted to put a plow on my Bronco. So, I just unbolted the bumper off the Bronco and then unbolted the plow assembly (with bumper still attached) from the F150 and swapped them. I don't remember all the years, but I'm pretty sure the 1979 Bronco had a TTB front end, which should be the same as the F150. In any case, as long as they both had the TTB front end, you can do the swap.
Old 11-01-2007, 07:39 PM
SpectreZ91's Avatar
SpectreZ91
SpectreZ91 is offline
1979 bronco had a Solid front axle..
1980 is the first year of the TTB.
Old 11-03-2007, 01:55 PM
2classics's Avatar
2classics
2classics is offline
a 79 bronco had ball joints not king pins. I know alot of people plow with older half tons. Not commercially.
Old 11-04-2007, 06:47 AM
ranger429's Avatar
ranger429
ranger429 is offline
They work fine for plowing. I've plowed with a couple of them. The short wheelbase definetly has it's advantages. The brown Bronco was only used for my driveway.
Old 11-04-2007, 10:19 AM
rsalter66's Avatar
rsalter66
Ya know maybe its just the newer broncos that I was thinking of? the only reason I say it tears up the front ends is because I've seen broncos that were used for alot of plowing and their front wheels were crooked from all the abuse they took hitting piles of snow with the plow while the 4 wheel was engaged? and I was told that it tears them up? I do not have first hand exsperiance with it myself
Old 11-05-2007, 10:26 PM
Nate81camaro's Avatar
Nate81camaro
Nate81camaro is offline
Originally Posted by ranger429
That looks sick!!
wharthog
WTB - Parts & other
01-22-2017 07:48 AM
blackburb
1997-2006 Expedition & Navigator
01-14-2017 10:39 AM
Firstonraceday93
10-10-2011 07:17 AM
mr patrick
New Member Introductions
09-19-2007 05:14 PM
Chad Winship
12-01-2002 03:08 PM
Quick Reply: Plow on a Bronco
