Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-30-2007, 09:55 PM
VINNIE JAMES is starting off with a positive reputation.
Can You Diesel Guys Tell Me About This
http://www.ford-trucks.com/forums/66...-about-it.html
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 10-30-2007, 11:46 PM
David85's Avatar
David85 is gaining momentum as a positive member of FTE.
I've never heard of a 6.6 diesel other than the duracrap/GMC, 6.9, 7.3, and 7.8 are the only ones I know of. Couldn't quite read the whole engine sticker, but the HP rating of 170, could make it a 6.9 (160-170@3300), but that engine was discontinued in 1988???? helluva deal though, 3500 for a 5 ton diesel cube van with low miles is a steal, where I am.
Maybe some one else can shead some light on what possible engine is in there (kind of curious myself).
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #3 (permalink)
Old 10-31-2007, 01:11 AM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.
My guess is a C7 Cat engine.
I can see valve lash specs on the sticker, so it is not an IDI engine.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #4 (permalink)
Old 10-31-2007, 07:00 AM
mistakenID is starting off with a positive reputation.
A quick search for info turned up a chart: ARB Approved Engine Families for the PCRT™ Particulate Filter
The chart showed engine ID LFM07.8EPC7 as a Ford engine, manufactured in 1990. There were cat, cummins, navistar, mercedes, isuzu, gm, hino ect. all listed.
I also found a used Ford 6.6 on truckpartsinventory.com
__________________
86 F-250 4x4
Cummins BT 5.9
GearVendor O/D
  #5 (permalink)
Old 10-31-2007, 07:26 AM
bilder12 is starting off with a positive reputation.
i do believe that ford used a brazilian manufactured in-line 6 engine in those trucks.
__________________
2000 super duty f-350 crew cab with training wheels, ats flip chip controller - hang on to it ! I did the air intake too - best thing since sliced bread.
  #6 (permalink)
Old 10-31-2007, 10:30 AM
tjc transport's Avatar
find me if you can!!!
tjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant future
that is the ford 6.6 liter inline 6 cylinder diesel. it is the smaller brother of the more popular 7.8 liter ford Brazilian diesel. it is kinda underpowered for a truck that size.
__________________
Join me in the New Jersey Chapter, CLICK HERE!
NEW JERSEY CHAPTER LEADER
Tom
65 falcon 2dr h/t hot 289/C4
66 7 litre 4 speed convertible
79 F250 4X4 plow rig 351M C6
88 superduty diesel 4X4 C6 and banks turbo
99 crown vic P71 interceptor
02 F250 superduty diesel 4X4 stretchcab shortbox, all better now!!
  #7 (permalink)
Old 10-31-2007, 01:46 PM
Is There Anything I Should Watch Out For With This Motor? Is There Anything I Can Add To This Motor? Thanks,vinnie
  #8 (permalink)
Old 10-31-2007, 02:48 PM
probably the best thing to add is JADO assist ...
i believe it was written about in the bible ... a loud roar moving slowly across the land
__________________
  #9 (permalink)
Old 10-31-2007, 03:59 PM
Quote:
watch for oil leaks, especially near the cooler.
watch the oil pressure. the oil pumps are getting hard to find.
dont overheat it. they blow head gaskets when thet get real hot.
about the only thing you can do to make it run better is open up the exhaust, and let it get plenty of air intake. other than that, there is really not much more you can get out of these engines .
removing the muffler will let it rev up a little faster, but not by much.
__________________
Tom
  #10 (permalink)
Old 10-31-2007, 04:19 PM
David85's Avatar
Quote:
watch the oil pressure. the oil pimps are getting hard to find.
dont overheat it. they blow head gasketd when thet get real hot.
So they can't be turbocharged reliably?
__________________
  #11 (permalink)
Old 10-31-2007, 04:43 PM
not really, cause they already have a turbo .
__________________
Tom
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
