How does the 4x4 work?
Old 10-30-2007, 08:01 PM
truckmonger1's Avatar
truckmonger1
truckmonger1 is offline
Someone please correct me if I am wrong with my assumptions. When you turn the button on the dash, the transfer case is engaged by an electric motor. The front axle is engaged by vacuum. I think my front axle is staying engaged all of the time. How can I test that? Thanks.
Old 10-30-2007, 08:15 PM
Ford Fx4's Avatar
Ford Fx4
Ford Fx4 is offline
You just about got that right....The front axle/front driveshaft is engaged by the transfer case... and the front hubs are engaged by Vacuum.
You can tell if your axle is not disengaging if
1 make sure the dash buttom is showing 2x4
2 start the truck
3 put it in park
4 put the E brake on
5 Get under the truck on try to turn the front drive shaft, if it is free turning it is working like it should, the front axle is disengaged. If the axle does not turn, then the transfer case is not disengaging the front axle, most likely the electric motor.
hope this helps
Old 10-30-2007, 08:31 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
last part of #5 should say- if the driveshaft does not turn, then the transfer case is not disengaging the front axle,-or the vacuum solenoid did not disengage inside the front axle.
Old 10-30-2007, 09:21 PM
ATC Crazy's Avatar
ATC Crazy
ATC Crazy is offline
Received 2,703 Likes on 1,316 Posts
Nope..."truckmonger" had it right. These trucks do not have vaccum hubs. The vaccum thing is on the front differential and it disengauges the passenger's side axle shaft from the inside (spider gears).
Pipelinewelder20
2004 - 2008 F150
06-01-2015 10:30 AM
Newreeve
10-27-2014 03:59 PM
h2ofowlhunter76
Offroad & 4x4
07-24-2013 08:01 PM
Czacha
1997 - 2003 F150
12-27-2009 03:19 PM
Quick Reply: How does the 4x4 work?
