Axle Code Chart - Ford Truck Enthusiasts Forums
Axle Code Chart
Old 10-30-2007, 05:25 PM
ctrain22 ctrain22 is offline
ctrain22 is starting off with a positive reputation.
Axle Code Chart
Does anyone have an axle code chart to decode the door jam sticker for axle ratio and type on a 2000 Excursion?
Old 10-30-2007, 08:01 PM
Zip's Avatar
Zip Zip is offline
Posting Legend
Zip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputation
If the codes are the same as a Superduty I may be able to help.
Old 10-30-2007, 08:53 PM
They should be (I hope).
Old 10-30-2007, 09:26 PM
7.3 4X4 7.3 4X4 is offline
7.3 4X4 is starting off with a positive reputation.
What's the axle code on your truck?
Old 10-30-2007, 09:34 PM
Zip's Avatar
Zip Zip is offline
Posting Legend
If you can give me the code I will see what my papers say.
Old 10-31-2007, 03:15 AM
Zip's Avatar
Zip Zip is offline
Posting Legend
OK here is what I have:
31-3.73 non-limited slip
C1-3.73 limited slip
32-4.10 non-limited slip
C2-4.10 limited slip
33-4.30 non-limited slip
C3-4.30 limited slip
36-4.56 non limited slip
C6-4.65 limited slip
That's the info I have. Hope it helps.
1980-1986 axle code chart needed Art 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 20 02-06-2017 02:01 PM
1984 F150 axle ratio ? pecanguy 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 08-19-2013 08:55 PM
wire color code chart Emel 6.7L Power Stroke Diesel 2 10-02-2011 11:29 AM
Door tag Axle code Festus Hagen Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 02-11-2011 06:22 PM
what does the F27 part mean of a VIN? masterbeavis 1973 - 1979 F-100 & Larger F-Series Trucks 4 06-06-2005 03:04 AM
Tags
2003, 2005, axel, axle, chart, code, decode, ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
