Resistance of '96 starter diode? - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
Old 10-30-2007, 02:00 PM
Pseudoname333 Pseudoname333 is offline
Pseudoname333 is starting off with a positive reputation.
Does anyone know the resistance value of a '96 starter diode?
Basically mine is gone and the van will not start without one.
Starter relay cluster contains 3 [FOAB-14B192AA as listed on relay] [FOAZ 14N089 A part number to order from Ford]
and 1 gray diode, in the frontmost slot and just plugs into two of the four slots, that looks like a big fuse.
Can someone tell me the part number and where I could get this part, my dealer said it was dicontinued or tell me:
-the resistance value
-where a manual or schematic that would list the value is
-somewhere I could find this info
Or, could some with access test diode for its resistance value
Old 10-31-2007, 12:43 AM
copper_90680's Avatar
copper_90680 copper_90680 is offline
copper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant future
Pseudonym
Welcome to our FTE forum
I'm confused. Diodes are semiconductor devices, whose resistances depends on the forward bias voltage. Ideally it's zero in one direction and infinite in the reverse direction. There are no fixed values. Are you sure you are talking about diodes? Where exactly is this thing?
Old 10-31-2007, 01:18 AM
krankshaft's Avatar
krankshaft krankshaft is offline
krankshaft is starting off with a positive reputation.
To test a diode use the diode function on your DMM to perform a voltage drop test. However on some larger diodes the voltage that a standard multimeter delivers isn't enough. So you have to test it with a load.
To test the diode with a load apply a low voltage AC current to it with a transformer and use a resistor as a dummy load to measure the output.
Check out this page for the schematic:
http://en.wikipedia.org/wiki/Rectifier
Follow the schematic for the half-wave rectifier where it says R is where you put the resistor. Now using your DMM measure the voltage from the resistor. Place your positive probe on one end and your negative on the other.
If you read a DC voltage the diode is fine. If you read an AC voltage the diode is shorted if you don't read anything the diode is open.
Old 10-31-2007, 01:20 AM
krankshaft's Avatar
If what you are referring to is indeed a diode the only thing that makes sense to me is that they used it to prevent surge current from destroying the relay coil.
If this diode bit the dust you should check the relay coil its across and make sure its not fried as well.
Old 10-31-2007, 05:42 AM
96_4wdr's Avatar
96_4wdr 96_4wdr is offline
96_4wdr is gaining momentum as a positive member of FTE.
the later Aeros with high speed processor for OBDII EEC-V engine control added an additional protection diode in the relay box to reduce further the EMF kickback voltage from the PCM relay to further protect the delicate PCM electronics. wiki relay protection diodes.
I've never seen one fail in Fords. forward and reverse bias test for proper diode action. test with high impedance R testing for leakage
if your's is missing, get a 3a or 6a 25v or 50v rectifier diode at Radio Shack and put in with band cathode end on +12v side contact in relay box socket.
this diode has nothing to do with the starter relay or start circuit.
always replace the PCM relay with one that has internal diode protection also. like wearing 2 condoms
additional protection internally in the PCM with V. surge protection devices
Old 10-31-2007, 11:20 AM
If that's the case, the only way this diode could have affected the starter relay is if it failed in shorted mode. However, that's highly unlikely since diodes usually fail in open mode. Could it be that you put this diode in backward so the current is going through it instead of through the coil?
A simple test will be to remove the diode and see if the starter cranks. If not, the starter itself or the solenoid are more likely culprits.
Old 10-31-2007, 01:36 PM
RE: 96 Aerostar Diode
I was told by the dealer the item was a diode and all I needed was the value and I could find a replacement, if I remember corectly it said diode on top and had a schematic symbol of a triangle intersecting a vertical line, the plug was lt. gray about 7/8'' high x 1-1/8' wd x 3/8" thk
Located in starter relay cluster (black about 8" lg x 2" wd with 4 plugs protruding from bottom) just under drivers side hood hinge.
in the frontmost, first of four slots, two of the four slots, looks like a big fuse.
Old 10-31-2007, 01:38 PM
3.0l Aeroster 2wd
Part is missing, I need a replacement or patch.
Old 10-31-2007, 01:43 PM
96 3.0l Aerostar 2wd diode resistance
Part is missing, vehicle won't start, need replcacement or value to substitute patch.
Old 10-31-2007, 03:04 PM
96_4wdr's Avatar
part # F2TF14A604AA
put in with diode cathode end marked -|<- toward brake master cylinder.
not listed in Motorcraft cross ref. and not found Ford dealer parts search.
called a PCM power relay diode
try your local pull it junke yard parts emporium, should be tons of Aeros, Ranger, Explorers etc with one
never seen one fail...someone must have a sick sense of humor to pull it out and take it.
Old 10-31-2007, 05:19 PM
krankshaft's Avatar
Quote:
Originally Posted by 96_4wdr
part # F2TF14A604AA
As 96 said you can pick up a replacment at Ratshack here is a link to what you need.
http://www.radioshack.com/product/index.jsp?productId=2062591&cp
Much easier then going to the U Pull It for such a small part IMO.
The cathode end is the end of the diode facing the dash:
Cathode
Old 10-31-2007, 07:31 PM
96_4wdr's Avatar
plug cathode end -| into front position in relay box pin 2 marked 454
plug anode <|- into pin #4 marked 16
Old 07-29-2016, 09:17 PM
smbamj smbamj is offline
smbamj is starting off with a positive reputation.
Where can I buy this
I need a replacement for FZTF-14A604-AA
'94 Ranger
Anyone know where I can find this?
Diodes moejr Electrical Systems/Wiring 6 12-05-2016 10:58 AM
Need part # Help Aneatria Hinojosa Ranger & B-Series 2 10-17-2016 09:01 PM
Diode + resistor in one package? M-13503, anybody know what this is? ctubutis 1987 - 1996 F150 & Larger F-Series Trucks 5 01-14-2012 12:50 PM
Value of Diode peterso 1987 - 1996 F150 & Larger F-Series Trucks 17 04-17-2011 09:17 AM
A/C clutch diode temeog 2004 - 2008 F150 1 07-22-2009 06:23 PM
Tags
14n089, diode, diodes, f150, f2tf14a604aa, foaz, foaz14n089a, ford, location, missing, pcm, position, relay, resistance, starter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
