300 6 No Spark at coil
Hi new here and to Fords so bare with me if I miss anything. Hav a 94 f150 with a 300 in it and I can't get any spark at the coil. It has powet to it but nothing comming out of it. Tried a new one and still same resultes. What am I missing? Any help would be great.
Thanks
Thanks
Probably the ignition module. They are known for going out. I keep a spare in the glove compartment. If you have a dwell meter you can check to see if the coil is being told to fire. Sometimes you can tell by putting a test light between the negative coil terminal and the positive battery post. If it flashes while cranking the coil is getting a signal. If it doesn't flash you don't know anything, but at least you tried something new.
cseich64
06-17-2013 04:06 PM
