Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Iowa Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Iowa Chapter Join Chapter, Leader: fellro86
  #1 (permalink)
Old 10-28-2007, 06:58 PM
goodgord goodgord is offline
Garage is empty, add now
goodgord is starting off with a positive reputation.
Cummins engine
If I install a cummins in my F350 does anyone know for sure if the 4R100 tranny will handle this power. I know it would need a different torque converter and a higher rear end. Right now it has a 5.4L gasser.
Thanks
Gordon
  #2 (permalink)
Old 10-28-2007, 07:35 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
1967 Ford Galaxie
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
as setup the 4R100 behind your 5.4 would NOT hold a cummins, heck it wouldn't hold a stock psd thats why Ford upgraded the 4R100 when it was used behind a 7.3 vs what was used behind a 5.4
__________________
Rob
Learn from your parents mistakes.......... Use birth control
  #3 (permalink)
Old 10-28-2007, 07:37 PM
I was giving thought to installing a dodge tranny along with it. Might be cheaper also
  #4 (permalink)
Old 10-29-2007, 06:49 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
It makes things a bit simpler if it is a 2wd. 4wd is a crap shoot as to the better way to go, but the 4R100 would still have to go. The claim is that the Ford diesel trannies don't hold up, but it also depends how crazy you are going to go with the motor. Also, a consideration is the bell housing mounting, it may be more trouble to get an adapter plate made. They are available for the diesel bells, but not as much for the small gas bells. I don't imagine they kept the bell the same as the 302, but even then, it limits the torque converter size, and the gas converter won't work well with the Cummins.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #5 (permalink)
Old 10-29-2007, 06:59 AM
Thanks guys,
I don't want any huge problems so I guess I will find a complete setup out of a Dodge.
  #6 (permalink)
Old 10-29-2007, 07:12 AM
fellro86's Avatar
1978 Ford F-150
Best way to go is get the whole truck, all the small stuff is well worth it. I bought a roll over with everything I needed, and then some, since it also had the gear vendors unit as well.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
