how to adjust volare front suspension ride height - Ford Truck Enthusiasts Forums
Old 10-28-2007, 01:55 PM
0to100to0's Avatar
0to100to0 0to100to0 is offline
0to100to0 is starting off with a positive reputation.
for those with the volare front end (my new truck has one), how do you adjust the ride height? I wanted to lower it a little bit and was wondering if anyone had any pics of which bolts I have to turn and which way to turn them.
thanks a lot,
Matt
Old 10-28-2007, 03:12 PM
CIAF's Avatar
CIAF CIAF is offline
CIAF is starting off with a positive reputation.
WOW.................Anyway, welcome to site. Just wondering, have you by any chance looked under the truck yet??. Are you a little familiar with the front end or the truck at all or did you just get it? Based on your question as to the bolt itself I would suggest you go straight to the alignment shop and have them adjust the ride height since the front end will need to be aligned after making an adjustment anyway. This adjustment is part of the alignment charge anyway so may as well take advantage of it and save your self the grief. BTW, there is a search feature on this site and there is a lot of info on the very same issue of ride height adjustment and so forth. Good luck .
Jon
Old 10-28-2007, 07:20 PM
raerjim's Avatar
raerjim raerjim is offline
raerjim is gaining momentum as a positive member of FTE.
Matt, if you'll look under your frontend,you'll see the head of a large threaded threaded rod, one on each side. They are angled rearward. "loosening" the right bolt will lower the left side suspension, and vice versa. Mark the heads and count the # of rounds backed off. Know that the more you lower, the lower the driving quality, as the tension is relieved on the bars.
Old 10-28-2007, 07:23 PM
TheWiz427's Avatar
TheWiz427 TheWiz427 is offline
TheWiz427 has a good reputation on FTE.TheWiz427 has a good reputation on FTE.TheWiz427 has a good reputation on FTE.
Welcome to FTE!
This is a breakdown of the volare suspension: http://www.geocities.com/indychamp/torsion/torsion.htm
At the end of the torsion bar theres a nut you turn and it will raise and lower the truck, But like the previous post you will have to get it aligned as it will throw it out of alignment.
Quote:
Yep it gets kinda squishy.
Old 10-29-2007, 02:52 AM
0to100to0's Avatar
thanks for the help guys..... that was perfect information..... and by the way i know that there is a search function for these forums, i used it and didn't get a clear answer.... wow, and i thought they were sarcastically harsh on stangnet forums, but wow, it seems people are the same everywhere you go.
thanks again,
matt
Old 10-29-2007, 07:05 AM
GreatNorthWoods's Avatar
GreatNorthWoods GreatNorthWoods is offline
GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.
Matt, when I took mine to two alignment shops they never touched the torsion bar adjustment. They just aligned it where I had it at the time. If you turn the bolts clockwise it raises the truck and counter-clockwise lowers it. Remember the bolt on the left side controls the right side height and vice-versa. You will need a 15/16 socket or box end wrench.
Old 10-29-2007, 08:19 AM
LEckart's Avatar
LEckart LEckart is offline
LEckart is starting off with a positive reputation.
Matt-
Welcome. Please don't take CIAF's comments the wrong way. Notice the "Good Luck" and smiley face figure. Sometimes the written word is much different than the thoughts behind it. You and your truck are very welcome here, as well as your questions and input. Since I have been on this site it is rare that anyone gets flamed unless they really start an "issue". Please post some photos of your truck and join in.
Old 10-29-2007, 03:23 PM
CIAF's Avatar
Quote:
Originally Posted by LEckart
Matt-
Yupp, No Sarcasam intended. After reading it over, it sorta looks like it. I understand your concern, my bad, so sorry Matt...And please, please do not misjudge the FTE site. it is the best board around and filled with great guys, some with thicker skin than others.
LEckart, good call, thanks..
Jon
Old 10-29-2007, 05:24 PM
delaney delaney is offline
delaney is starting off with a positive reputation.
Smile
Quote:
thanks again,
matt
I would have been offended with the reply you got also. When I read the response my thought was why can't some people politely give a reply without being obnoxious.
Old 10-30-2007, 01:08 AM
0to100to0's Avatar
no harm, no foul. i put some pics in my gallery.
matt
Old 10-30-2007, 08:17 AM
TheWiz427's Avatar
matt
Nice! Looks like a great start!
Old 10-30-2007, 09:07 AM
LEckart's Avatar
Matt-
Nice looking truck. I think you might be the first one on the forum to have the BW conversion. It has been discussed but I don't recall anyone doing it as yet. Did you do it or was it already done when you purchased the truck?
Old 10-30-2007, 05:19 PM
Jag Red 54's Avatar
Jag Red 54 Jag Red 54 is offline
Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.
Yep, 02100 has got the right questions. Better to ask before you start experimenting. Lower looks cool but a lot of people complain that the ride is too soft and mushie on corners. I adjusted mine up much higher than most and the ride was rough. Once you have experimeted with the ride height and gotten it just the way you like it, take it to the alignment shop.
Just a suggestion, I would recommend doing the adjustments with the tires lifted off the ground to relieve the stress on the threaded adjustment rod. Then, after you have lowered or raised both sides the same number of turns, drive the truck out into the street and then back in the shop. This gives the suspension a chance to adjust the placement of the tires to the new Torsion setting. Good luck, Jag
Old 10-30-2007, 08:41 PM
0to100to0's Avatar
it was already done when i got the truck by a professional metal body guy. it looks like he did a good job, there is a ridge on the back of the cab where the old metal and the new metal meet though.... also, i think the panel might have been a little warped from the welding because the rear window did not want to go in. i had to bang on it and squeeze the glass in. however, it looks great now.
matt
Old 08-17-2014, 09:01 PM
Don Vito Don Vito is online now
Don Vito has a great reputation on FTE.Don Vito has a great reputation on FTE.Don Vito has a great reputation on FTE.Don Vito has a great reputation on FTE.Don Vito has a great reputation on FTE.
I've searched all over the web for a image of the bolt/nut that you loosen to lower the volare suspension, but can't find any, I assumed it would be a big nut somewhere at the end of the torsion bars but mine seem to be capped, I think Maybe I'm looking in the wrong place.
but I don't see anything, anyone have a pic of it?
Thx in advance Don
noise in volare suspension papabills54 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 04-18-2016 04:04 PM
Volare Height Red Voodoo 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 07-28-2015 05:40 PM
front shocks on a volare suspension papabills54 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-29-2015 11:02 AM
Too rough, stiff, solid ride sparky 1948 - 1956 F1, F100 & Larger F-Series Trucks 62 07-02-2008 10:50 PM
Need help adjusting Volare IFS LEckart 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 07-07-2005 12:25 PM
Tags
2009, adjust, adjusting, adjustment, end, f150, front, height, ride, suspension, trucks, valore, volare
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
