Ford Excursion Vallet/override Button?
Old 10-28-2007, 11:24 AM
Jeepmb's Avatar
Jeepmb
Jeepmb is offline
Arrow Ford Excursion Vallet/override Button?
Hey,
I have an 2001 Deisel Ford Excursion. For a time now it refuses to try and crank, you just hear a click, and then nothing. I think it has somthing do do with the alarm system and i wan't to deactivate it. Supposidly there is this vallet/override button or switch somewhere but i can't find it to save my life. Anyone here know where it is, or if it is the same button as the fuel pump reset button under the glovebox?
Old 10-28-2007, 11:37 AM
shadowdd's Avatar
shadowdd
shadowdd is offline
Is it a factory alarm? If it is an aftermarket unit if could be anywhere but usually contained in the driver foot well area. I havn't heard of the factory unit having a valet button.
Bryan
Old 10-28-2007, 11:52 AM
Jeepmb's Avatar
Jeepmb
Jeepmb is offline
It is a factory alarm
Old 10-28-2007, 03:24 PM
afreemanmd's Avatar
afreemanmd
afreemanmd is offline
this may sound stupid, but is it a dead battery? I know the diesels take a lot of juice to crank over.
just a thought :-)
Old 11-02-2007, 02:38 PM
Wyldnative's Avatar
Wyldnative
Wyldnative is offline
You may try to pull up on the shift lever as it may be out of alignment and not showing that the vehicle is in park thus not letting it crank over.
Old 11-02-2007, 06:08 PM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
Factory "alarms" do not have a Valet feature. In fact, they aren't really alarms at all. They are passive. Lock the doors with the windows down and you can reach in an unlock the doors and nothing will happen. It is the key that is the "key" to the system. You need the PATS key to turn the starter over.
Sounds as if you've got a bad battery cable, connection or ground.
Old 11-02-2007, 06:49 PM
K9BELLA's Avatar
K9BELLA
K9BELLA is offline
I second Monsta, try the battey connection.
feyerman
11-11-2014 10:16 AM
Ristow
06-03-2014 08:10 AM
geckocub69
1997 - 2003 F150
06-28-2007 08:34 PM
Sarge2155
2004 - 2008 F150
02-22-2007 10:09 PM
Quick Reply: Ford Excursion Vallet/override Button?
