Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-28-2007, 01:56 AM
White_Knight's Avatar
White_Knight is starting off with a positive reputation.
Exclamation 6.9 IDI into '77 F250 4wd
OK, here's what I have:
Donor:
1986 F250 2wd 6.9 IDI/C6 trans. Rolled over, frame tweaked, body
and roof damage but plenty of good parts. Still cranks and runs.
126,000 miles
Victim:
1977 Ford F-250 XLT Ranger 4WD longbed with anemic 400 ci V8/
C6 married NP205 combo. Everything great except the engine- one
cyl. head cracked. I really don't want to rebuild it or swap it out
with a 460. Thought about a 351. Then dismissed it when I found the
donor. I'd rather rebuild and Banks Turbo a 6.9.
Both are paid for. The wife has a new Lexus. I will not be hindered.
I know the 6.9 weighs in more than the 400. On the upside I have all
the parts from a donor. Both trannies are the same- C-6s, and I think the bellhousings are the same. May need to get a diesel C-6 4WD trans, don't know if the gas C-6 can be beefed up with parts or how much is interchangeable.
I've come across 2WD versions of this swap, but not a 4WD. Any ideas, bits
of wisdom, caveats, puzzled looks all welcome.
Thanks!
Mark
__________________
Amateur Radio Operator KE5LIB
1977 F-250 Ranger XLT 4WD Styleside "Wicked Wilma" - now packing a 6.9 IDI!!!
"Try not! Do, or do not. There is no try." - Master Yoda
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 10-28-2007, 10:05 AM
starmilt is starting off with a positive reputation.
Wkite Knight I have a 76 with a 6.9 it is 4sp with divorced 205 made it easier you will have to use diesel trans but complete tear down is in order to use tail shaft out of 4x trans and tail housing. some chevys had splines long enough all you had to do was cut tailshaft off and swap tail housing. you will probabily want a small body lift because the bellhousing has to be twisted just right to remove impossible with a trans hooked to it
  #3 (permalink)
Old 10-28-2007, 10:43 AM
Ford428CJ's Avatar
Ford428CJ is starting off with a positive reputation.
I'm almost done with mine! I put a 6.9 ATS Turbo in my 79 F250 Super Cab. I would do a 3" body lift if it was me. It gave the Turbo plenty of room and easy to work with. You need the Gas tranny output shaft for your C6 Diesel tranny and put the Diesel governor back on it. You will need to cut and box in the front cross member (for the oil pan).
I used the 2 plates (where the motor mounts sit on and connect to the frame )out of a 85 Ford. On the passenger side (on the 79) I plated the left side of the frame, so it was nice and flat across the top and drilled my 2 holes for the mounting plate.
On the driver side I had to make a mount and weld it to the frame (an L shape bracket with gussets). Used the mounting plate and bolted it to the L shape bracket. Then I welded up a cross member to tie in the 2 plates together across the bottom!
I'll take some pictures here and you can see for yourself.....
__________________
Wes Adams FORD428CJ
Built Ford Tuff With Good Ford Stuff
79 F-250 X-Cab 4x4 6.9 Turbo Diesel
64 Falcon X-Ram 428
55 FORD Truck 4-link Rides on air with X-Ram 428
67 Stang 351 C/J
2000 Yamaha V-MAX VMOA#4277
  #4 (permalink)
Old 10-28-2007, 01:05 PM
David85's Avatar
David85 is gaining momentum as a positive member of FTE.
Diesel and gas bellhousings are not the same, and will not interchange in any way. Internal parts should be the same, and even if not, C6 parts are cheap on Ebay.
There seems to be a lot of these 70s diesel conversions out there lately . Please post pictures.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #5 (permalink)
Old 10-28-2007, 04:00 PM
Thanks guys!
I went ahead and got a 3" body lift kit,
so that worked out good. I'll research
the tranny part- ran across a rebuilder
whose specialty is C6s. Please post
those photos- especially of the cross
member mod- do you think the '86's
mount brackets would work? Thanks
again, as I can I'll put in the pix of my
rig!
Mark
__________________
  #6 (permalink)
Old 10-29-2007, 06:23 PM
Ford428CJ's Avatar
[quote=David85]Diesel and gas bellhousings are not the same, and will not interchange in any way. Internal parts should be the same, and even if not, C6 parts are cheap on Ebay.
/QUOTE]
I did say that. BUT you will need the output shaft of the gas tranny and install it on you C6 Diesel tranny! They made 2 different output shafts and you need to use the longer one to get it to work. Otherwise the Diesel will be right in the firewall & it uses a shorter adapter (unlike the 70's C6 adapters). JMHO
__________________
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
  #7 (permalink)
Old 10-31-2007, 09:11 AM
Ford428CJ's Avatar
Hey White Knight,
I got some pictures for ya but you are going to have to wait until Monday for me to post them. I have to work this weekend and try to get my truck done by then as well. Don't worry, I'll get ya the pics LOL!
__________________
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
