Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-27-2007, 11:06 PM
Beanscoot Beanscoot is offline
Garage is empty, add now
Beanscoot is gaining momentum as a positive member of FTE.Beanscoot is gaining momentum as a positive member of FTE.
1.9L head with micro cracks
Hi everyone, I was given a friend's '92 Escort with a 1.9 engine that was leaking coolant into a combustion chamber due to a small channel eroded into the head. The car is in excellent condition otherwise so I had the head milled to clean up the damage, and had a valve grind and jet-clean done.
Now as I put it back together I notice tiny hairline cracks between the valve seats at their closest distance to each other. There weren't any previous problems with the car before the recent leakage, so I wonder if these cracks can be ignored. I'm guessing by the carbon pattern on the cracks that they've been there for a long time.
  #2 (permalink)
Old 11-01-2007, 12:17 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
We don't really cover the 1.9 in here as it wasn't available in trucks but I can tell you from personal experience that they are indeed prone to cracking the heads.
I'd take the head back to the machine shop that did the work. That's something that they should have caught. I've heard of many instances where heads were cracked between the valve seats like that but the cracks didn't extend into any coolant passages and didn't cause a problem. However, with aluminum heads, I'd be afraid of the seats coming loose and dropping out...
__________________
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 11-01-2007, 12:33 AM
Thanks for the advice. I just brought in the bare head with loose valves for a super economy grind so I don't blame the shop. I could have had them pressure test it I suppose but didn't.
I talked to a good mechanic today who assured me that a lot of these type engines have the tiny cracks and usually they would be okay. It's hard to even find a core with no tiny cracks for some motors apparently.
Kind of reminds me of flatheads...
  #4 (permalink)
Old 11-23-2007, 08:22 AM
tomw tomw is offline
1985 Ford Ranger
tomw has a good reputation on FTE.tomw has a good reputation on FTE.
The original heads for the Escort were cast in Italy. If that tells you anything. They are known to be VERY easy to crack if they get overheated. Some will have leaking head gaskets between cylinders, and be diagnosed as a cracked head. Many Escorts went to heaven because of the repair cost when the rest of the car was in excellent shape. It was not economic to put $500-800 into a $1500 car... at least a lot of people thought so. So they got car payments of $200-300 for a beater, and paid for the head repair in the next two-three months, and again .. and again until they paid for their 'new' car. In other words, if the rest of the car is on good enough shape, and you are not tired of it, repair is often, if not always, less than 60-72 months of car payments. Your choice. But, you will get over 30 mpg for a long time if you keep it in repair.
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #5 (permalink)
Old 11-24-2007, 01:32 PM
Hi Tom W,
Interesting that those heads were cast in Italy. I repaired the car and it is running fine except for an uneven idle, and the heater being soso in output. The car does have an excellent body and interior though so I'll try to sort out the little problems.
I was told the idle problem was due to a bad temp. sender which should be a cheap fix. You are right about the mileage, this car belonged to a friend who kept a log of mileage and frequently got over 40 miles per (imperial) gallon, mostly highway dri ving. I got hold of a parts car that also had a bad head gasket and therefore was free. It was also in excellent rust free condition but slated for junk because of the leak. Unfortunately I couldn't keep it around due to me living in the city, but I stripped the most useful parts I could think of.
  #6 (permalink)
Old 07-12-2009, 03:17 PM
An update on this car: Well I've been using it as a daily driver for over a year, got it really hot once (the electric radiator fan failed to come on), and there's been no problems.
I am repairing another similar car that had a cracked head. I had to remove a couple at the junkyard before I found a good one, and even it has the micro-cracks between valves. But I'm confident now that it will be fine after a regrind with new exhaust guides.
The major cracks in that bad head were quite obvious and leaked heavily during leak testing, while the micro-cracked head showed no leakage under the same test.
  #7 (permalink)
Old 04-07-2010, 08:55 PM
whitefordexplorer's Avatar
whitefordexplorer whitefordexplorer is offline
1991 Ford Explorer
My Garage
whitefordexplorer is gaining momentum as a positive member of FTE.whitefordexplorer is gaining momentum as a positive member of FTE.
cooksmobile@yahoo.com MUSCLEDRIFTER
my philosophy on the 1.9l.... as soon as it gets hot, throw the head in the nearest trash can. i had a '95 'scort that ran awesome after i replaced the head. i drove from hesperia, CA to vegas, around vegas for two days, and back to banning, CA and only had to fill up once at state-line. and i did 85-90m.p.h. the whole way. i sodl the car back to the lady i bought it from who needed it for her son, and she loaned it to someone and they wrecked it!
__________________
-Landon
My wife said if i didnt stop spending money on my truck and not her, she would leave..... My new girlfriend loves my truck!
if it has t**ies, tires or tools, it has my full attention.
  #8 (permalink)
Old 04-08-2010, 02:16 PM
I hope she saved the head!
The car with the micro cracks in its head continues to run fine and shows no sign of coolant leakage. I flushed out the heater core with the garden hose and now I even get heat!
  #9 (permalink)
Old 07-23-2011, 02:18 PM
Ricohman's Avatar
Ricohman Ricohman is offline
Ricohman is starting off with a positive reputation.
This is good to know as I'm doing this repair on my boys car.
The head I pulled at the wrecker is good except for those tiny cracks you speak of.
We are going to put it togther and hope for the best!
__________________
2010 F350 4x4 6.8 XLT XTR CC
Tags
19, 1992, 19l, 92, bare, crack, cracked, cylinder, ford, head, issues, micro, motor, seats, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
