Rebuilding rear end for F150 - Ford Truck Enthusiasts Forums
Old 10-27-2007, 10:51 PM
DaBossF250 DaBossF250 is offline
DaBossF250 is starting off with a positive reputation.
I searched and searched for the howling problem for the F150's and found and had people reply that it is most likely the rear end. And my truck (99 F150 2WD) has 186,000 miles on it and the howling noise is annoying! And It prolly needs a rebuild with all those miles. So I want to rebuild it but I dont want to spend all the money because I am going to college. But I am taking automotive classes, so should I try to rebuild it myself in class? or should I let a professional do it? I am just trying to save money by doing it myself.
Old 10-28-2007, 01:31 PM
anyone suggestions?
Old 10-28-2007, 07:50 PM
lasthighboy's Avatar
lasthighboy lasthighboy is offline
lasthighboy is starting off with a positive reputation.
do it urself in class. most schools will let u work on ur own stuff and dont charge for labor. u will get the experience of doing it, and ull want to make sure u do it right because u r the one that will have to live with it. plus ur teachers will be there to help you and they should know what they are doing, probably as good or better than someone in a shop would.
Old 10-28-2007, 09:32 PM
ewturtle's Avatar
ewturtle ewturtle is offline
ewturtle is starting off with a positive reputation.
Being able to setup gears in an axle is a great tool to have. I wish I knew how to set them up.
I was going to post to just find another axle in a boneyard but since you have access to someone to help you learn how to set up gears, then go that route, you wont be sorry. It might cost a little more money but you'll be much better off in the long run.
Old 10-29-2007, 12:22 PM
When doing a rear end rebuild, what all I should i replace?
Old 10-29-2007, 12:51 PM
75F350's Avatar
75F350 75F350 is offline
75F350 is a name known to all75F350 is a name known to all75F350 is a name known to all75F350 is a name known to all75F350 is a name known to all75F350 is a name known to all
When you see what is required, you will find that not replacing all of the bearings will prove to be a waste of time. Since most of the bearings have been rotating roughly the same amount, and one or more has gone (going) bad, it is safe to say that all of them are on thier last leg.
Any good re-build will require a small shim pack, since some of the smaller shims may need to be replaced. You will keep in mind that the shims removed shoud be kept in the same order to get a baseline reference for the new installation. You may get away with re-using the old gear set, but only after careful inspection. With your master overhaul kit should come with all new seals and a new crush sleve. The rest is labor. Now if you have a LS unit, you will also need to rebuild it. The rear axle rebuild is not cheap.
Here is a smal link from others in your situation, and you can use the link to navigate for other assistance.
Good luck.
http://autorepair.about.com/library/a/1d/bl444d.htm
Old 10-29-2007, 03:20 PM
how hard is it to get a used differtial and swap another one in from a junkyard?
Old 10-29-2007, 10:10 PM
probably actually cheaper and easier than any other option
Old 10-29-2007, 10:44 PM
where can I find a used one at? for a good price?
Old 10-29-2007, 11:32 PM
75F350's Avatar
Quote:
You are going to shop for a complete axle, drum to drum, or disc to disc.
If you shop for just a differential, you may end up with just a carrier, and you need a complete axle assembly. You could re-use your brakes and such, but in order to eliminate any set-up of gears, you need the complete assembly, housing and all. Then all you have to do is unbolt the springs from the u-bolts, remove the driveshaft, swap out the brakes (if you buy an axle without them) and bolt up the new one. Simple as that.
Old 10-29-2007, 11:59 PM
I am looking around for a complete axle would like disc brakes. maybe junkyard?
Old 10-30-2007, 12:18 AM
75F350's Avatar
Thats right. Junkyards are the way to go. Do make sure you can get some type of warranty, and inspect for obvious damage.
You will also need to know your current gear ratio so you can match it with the replacement unit.
Old 10-30-2007, 12:24 AM
75F350's Avatar
This is a thread that is cirrently running. It indicates only one of the potential problems with trying to do this yourself. It also has a pic of a rear axle similar to yours.
http://www.ford-trucks.com/forums/66...rear-diff.html
Rear axle rebuilders in Central PA? '49 F3 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 01-03-2015 08:44 AM
2002 Explorer rear end howl. compaddict Explorer, Sport Trac, Mountaineer & Aviator 7 03-18-2014 06:23 AM
wheel bearing howling dakota1820 1987 - 1996 F150 & Larger F-Series Trucks 16 01-04-2013 06:43 PM
'68 Mustang EFI fuel pump WOES Scot General Automotive Discussion 3 06-24-2012 11:07 PM
Help! (new guy) IWE & 4WD Nightmare tsunami23 2004 - 2008 F150 15 03-02-2011 11:45 AM
Tags
150, 1999, 99, differential, end, f150, ford, instructions, junkyard, low, price, quote, rear, rearend, rebuild, truck, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
