Looking to turn up the injector pump on my 1992 7.3L IDI
I have a 1992 F-250 7.3L IDI with an aftermarket turbo. It still has the stock injector pump. Was wondering if the injector should be turned up because of the aftermarket turbo being put on the truck? and if it should be turned up how do you do it?
92F3507.3LIDI
Welcome to FTE and the IDI diesel forum.
First I would recommend installing a pyrometer to monitor the exhaust temps.
Turning the fuel up can raise the exhaust temps to the point it can damage the pistons which start to melt at 1250 degrees.
Do you see any black smoke when you floor it?
If you do, you probably have enough fuel.
If not there are directions here,
https://www.ford-trucks.com/lc/lc.ph...520article.htm
F-250 WARHORSE
10-07-2016 09:41 AM
90cclb4x4IDIzf5
06-14-2016 05:07 PM
947.3lturboD
07-02-2015 10:49 PM
