Flathead Thermostat:
Old 10-27-2007, 11:25 AM
leonharu's Avatar
leonharu
leonharu is offline
I know this has been brought up a million times ,but here goes again.Which is the best to use for the best cooling on a 1952 Ford 239 flathead?A 160 or a 180 degree thermostat?Can anyone give me some direction on this?Thanks,Russell
Old 10-27-2007, 12:15 PM
F6Guy's Avatar
F6Guy
F6Guy is offline
from my personal experience with my truck, a 180 degree thermostat. A 160 just runs to cool unloaded and to hot when its working.
Old 10-27-2007, 02:01 PM
propane32's Avatar
propane32
propane32 is offline
160,s working great in mine
Old 10-27-2007, 04:21 PM
F6Guy's Avatar
F6Guy
F6Guy is offline
by works fine do you mean it does not overheat? My truck would run 150 degrees all day long without a load which is way too cool for me as my engine runs alot better with the 180's for instance it burns the fuel alot better my plugs are not nearly as dark as they were before and I had to turn my idle down a hair as it idled faster once it got to operating temp. Also when I hauled a load it would run around 230 degrees vs 200 with the 180's. I noticed you go by propane 32, did you modify your engine to run on propane?
Old 10-27-2007, 09:08 PM
mtflat's Avatar
mtflat
mtflat is online now
I run 180's for the same reasons F6guy talked about.
Old 10-27-2007, 11:23 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Engines wear faster at cooler temps. On flatties, it builds sludge from vapors that don't evaporate. If it overheats with 180's, it will overheat with 160's.
19fifty4
Flathead V8 & Flathead 6
10-27-2013 09:57 AM
jmadsen
22
03-15-2012 07:51 PM
John - NNY
07-08-2011 09:31 PM
51phil
05-30-2011 06:31 PM
redstone
1947 and Older Ford Trucks
09-20-2002 05:05 PM
Quick Reply: Flathead Thermostat:
