Does bioD hold more water than #2 diesel?
Old 10-29-2007, 11:49 AM
MikeSDK's Avatar
MikeSDK
MikeSDK is offline
Just had a thought, maybe some of you know the answer. I know that B20 (which I've been running for 5-6 mos) has a couple % points lower BTU than #2, but I'm not sure that a (possibly) 2% decrease in BTUs would cause the 50 - 100 degree drops in EGT that I'm seeing.
So, just a thought, but would Bio hold more water than regular diesel, thereby mimicking a bit of 'water injection effect' as a side effect, and as a result causing cooler temps? Hmmm........
Old 10-29-2007, 12:32 PM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
Bio Diesel has a higher Cetane rating than Dino. That can cause a drop in EGT.
BD may be slightly more hydroscopic than #2 because it is slightly polar, due to the ester bond, and #2 is non polar. As to the water injection effect I just don't know.
'88 E-350
Bio-diesel, Propane & Alternative Diesel Engine Fuels
13
01-08-2011 07:10 PM
Dave Barbieri
10-16-2005 10:39 PM
BigF350
07-22-2005 05:31 PM
Greywolf
127
05-20-2005 07:19 PM
TheImpaler
13
06-14-2004 08:43 PM
Quick Reply: Does bioD hold more water than #2 diesel?
