Remove cupholder from dash
Old 10-26-2007, 12:24 PM
mattyk6_bdr's Avatar
mattyk6_bdr
mattyk6_bdr is offline
How do you remove the cupholder tray from the dash?
Thanks!
Old 10-26-2007, 12:43 PM
150mudder's Avatar
150mudder
150mudder is offline
when you pull the cupholder out. when you look along the top part there should be two tabs that stick up and prevent removal. take a flatblade screw driver and press them down and out it should come.
Old 10-26-2007, 01:24 PM
chapinjohn's Avatar
chapinjohn
chapinjohn is offline
My cupholder seems to need more "pull"
than "push" to get open. Is it perhaps
missing a spring?
John
Old 10-26-2007, 01:42 PM
150mudder's Avatar
150mudder
yea when i went to take mine out, while pulling it out there should be two tabs you should have to press down for it to pull out smooth. that was the case for mine. maybe mines broke.
Old 10-26-2007, 07:57 PM
B's FX4's Avatar
B's FX4
B's FX4 is offline
i never use mine
Old 10-26-2007, 08:32 PM
duggyb's Avatar
duggyb
duggyb is offline
missing a spring?
John
i have the same problem....i really need to PUSH on it to get it to work.
THNX
Duggy
Old 10-26-2007, 08:59 PM
chapinjohn's Avatar
chapinjohn
On the front there is the word "push".
I push and nothing happens, so I have to
pull on the bottom to get it open. I did
manage to get the whole thing out
(as 150mudder indicated) and see a spring
or wire that it pushes against. No way
to get to spring with cupholder in place.
jejenkins417
06-26-2011 04:57 AM
RacerLT250R
1999 to 2016 Super Duty
11-20-2007 05:35 PM
rschleicher
1997-2006 Expedition & Navigator
07-15-2004 12:04 PM
oldblue18
03-06-2002 11:07 AM
Quick Reply: Remove cupholder from dash
