Remove cupholder from dash - Ford Truck Enthusiasts Forums
Old 10-26-2007, 01:24 PM
mattyk6_bdr mattyk6_bdr is offline
mattyk6_bdr is starting off with a positive reputation.
How do you remove the cupholder tray from the dash?
Thanks!
Old 10-26-2007, 01:43 PM
150mudder's Avatar
150mudder 150mudder is offline
150mudder is starting off with a positive reputation.
when you pull the cupholder out. when you look along the top part there should be two tabs that stick up and prevent removal. take a flatblade screw driver and press them down and out it should come.
Old 10-26-2007, 02:24 PM
chapinjohn chapinjohn is offline
chapinjohn is starting off with a positive reputation.
My cupholder seems to need more "pull"
than "push" to get open. Is it perhaps
missing a spring?
John
Old 10-26-2007, 02:42 PM
150mudder's Avatar
yea when i went to take mine out, while pulling it out there should be two tabs you should have to press down for it to pull out smooth. that was the case for mine. maybe mines broke.
Old 10-26-2007, 08:57 PM
B's FX4's Avatar
B's FX4 B's FX4 is offline
B's FX4 is starting off with a positive reputation.
i never use mine
Old 10-26-2007, 09:32 PM
duggyb duggyb is offline
duggyb is starting off with a positive reputation.
missing a spring?
John
i have the same problem....i really need to PUSH on it to get it to work.
THNX
Duggy
Old 10-26-2007, 09:59 PM
On the front there is the word "push".
I push and nothing happens, so I have to
pull on the bottom to get it open. I did
manage to get the whole thing out
(as 150mudder indicated) and see a spring
or wire that it pushes against. No way
to get to spring with cupholder in place.
F250 bench seat Cupholder Mod Big Vic 1999 to 2016 Super Duty 0 02-04-2014 04:04 PM
In dash cupholder jejenkins417 Excursion - King of SUVs 4 06-26-2011 05:57 AM
2000 F250 Cupholders RacerLT250R 1999 to 2016 Super Duty 3 11-20-2007 06:35 PM
dashboard cup holder stuck "in" rschleicher Expedition & Navigator 10 07-15-2004 01:04 PM
Armrest/Cupholder removal? oldblue18 1999 to 2016 Super Duty 4 03-06-2002 12:07 PM
Tags
2002, 2003, cup, cupholder, dash, f150, f250, ford, holder, problem, pull, pullout, remove
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
