Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 10-26-2007, 08:58 AM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Garage is empty, add now
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
ATTN BioDiesel Experts...
I was in a discussion in the 7.3 forum about BD and I started wondering what the safe temps are for running the various blends. Now that we're (FINALLY!!) seeing cooler temps here in North Texas, I'm curious if I can run B100 with some kind of anti-gel like DK in the white bottle, or should I stay at B20 or lower? I've "heard" that B100 can start to gel a lot sooner than dino (like in the 40s or 50s), so I'm curious. Also, is there a significant difference between soy BD & corn BD regarding gel temps?
Thanks for any insight!!
__________________
  #2 (permalink)
Old 10-26-2007, 10:49 AM
N2ZPY N2ZPY is offline
N2ZPY is starting off with a positive reputation.
B100 will gel sooner. I am currently seeing temps in the high 30s low 40s in the morning here now. I have had no issues so far. I am getting ready to start blending with Kero. I have a bunch of mason jars that will hold different blends so I can see how the temps effect them. How low the bio can go before it clouds is depends on what stock it is made from. I am using soy and canola (2 of the best to start with). From what I have heard the treatments don't work as well with bio.
Kevin
  #3 (permalink)
Old 10-26-2007, 03:43 PM
Izzy351's Avatar
Thanks for the reply, Kevin. So I should be good to go here in North Texas for a while on B100, at least for a while. We rarely get below that in the winter, but do occasionally. Last night was low 40s -- coldest since before Spring.
I see you're a ham -- me too. Call is N3JI.
Thanks again!
__________________
  #4 (permalink)
Old 10-27-2007, 06:01 PM
Izzy351's Avatar
BUMP... Anyone else with some inputs here??
__________________
  #5 (permalink)
Old 10-27-2007, 07:02 PM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
bigredtruckmi has a good reputation on FTE.bigredtruckmi has a good reputation on FTE.bigredtruckmi has a good reputation on FTE.
Sorry but corn is used for ethanol which is used in gasoline.
You will be safe at the B20 level until +32 degrees unless you use an antigell additive. One way to test it is just like n2ZPY says. mason jars at different temps in the frig. Don't know what your wife would say, but mine. Don't want to think of it.
__________________
red 04 F250 build date 04/04 6.0 PSD ,auto,cc, xlt ,sb, moon roof, 4X4, off road pkg, sports pkg., tow pkg,camper pkg,FX4, electric shift on fly
93 f350 7.3 , 5 speed manual, ext cab, long box 240K+ miles
1967 C700 farm truck
30 ft travel trailer
Vietnam Vet/ OS1 USN/USNR retired 26 years
B5 soydiesel user
Sirius radio
  #6 (permalink)
Old 10-27-2007, 09:43 PM
cookie88's Avatar
cookie88 cookie88 is offline
2001 Ford F-250
cookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant future
f250juggernaut
Blend to B80 and I doubt you'll ever have a problem in Tejas. Even assuming the "animal fat" bio that seems to be prevalent down here.
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
  #7 (permalink)
Old 10-27-2007, 11:26 PM
adambomb's Avatar
adambomb adambomb is offline
2005 Ford F-350
adambomb has a good reputation on FTE.adambomb has a good reputation on FTE.
i live close to the beach in southern california so run b100 all the time no problem. last winter i drove to the local mountains to go snowboarding and at night it was in the mid 30's truck started up fine on the soy b100. i know i was pushing the limits and it could have started to cloud/gel so this year i might pump in a little diesel before i go up the mountain just to be safe.
__________________
2011 Escape Limited v6 (Loaded) ESP 7yr/65k and Full Ford Maintenance Plan
2005 F350 6.0 (modded) ~450rwhp/900+ft/lb tq
1999 F350 7.3 (normal mods + 13" King Suspension on 40's)
1998 F150 (basic mods + 7" Suspension on 35's/Prerunner fiberglass and skidplace)
1994 Bronco (normal mods + 9" Coil Suspension on 35's)
  #8 (permalink)
Old 10-31-2007, 05:46 AM
We have finally had a good cold snap so I have some figures to throw out. I have a jar of B100 that was processed 2 weekends ago and washed/dried this past weekend. Yesterday I woke up and the temp was 22*F The jar was about 50%/50%......solid on the bottom and sluggish but still flowing on the top. This morning I am at 25*F and the whole jar is clouded but still liquid. Time to start cutting with some #1. I had no troubles yesterday morning as I have the rear tank full of B100 and the front is about B50 with #2 mixed at this point.
Kevin
  #9 (permalink)
Old 10-31-2007, 09:23 AM
IABill's Avatar
IABill IABill is offline
IABill is gaining momentum as a positive member of FTE.
Wink
Here ia a link to a place I found: http://www.technol.com/index.html
looks like they will have what you need. Just bought a quart form a local dist here. I will let you know how it works starting to get close to 32deg at night here so time to start dosin my fuel
__________________
Light travels faster than sound.
That's why some people appear bright until you hear them speak.
2007 F-350 Lariat CC,LB,SRW,2x4, Brite Box, High Idle sw, No Kitty & Straight Pipe, Blue spring & Sinister coolant filter & Fumoto.
Tags
biodiesel, california, experts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
