Easy Cold starts, NO GPR - Ford Truck Enthusiasts Forums
Old 10-26-2007, 06:31 AM
dinikin dinikin is offline
dinikin is starting off with a positive reputation.
Well, with so many treads on hard cold start I wanted to ask a questions.
Is there any damage to the Glow plugs or anything else if GPR is unpluged/broken. Mine is busted at the connectors so I disconnected it totally.
It only takes a crank or two to start it Up, there is barely any visible smoke out of the exhuast.
Currently there is only 37K on the engine(original).
The temperatures here now around 44 F.
I will eventually put a new one in when I find long lasting one .
Old 10-26-2007, 07:15 AM
bkcowboss bkcowboss is offline
bkcowboss is gaining momentum as a positive member of FTE.
http://guzzle.rbmicro.com/mods.html
This is what I am going to do when my relay goes out again, I think (it is only my opinion) that leaving GP's out of service for long periods of time causes carbon to build up on them and then makes them difficult to replace because the element is larger than the hole. I would imagine that those individuals who break plugs off in their truck, that plug has not worked for a while for one reason or another. I would get the system back up and running soon, doesn't need to be today, but don't wait a couple of months either, you might regret it.
Old 10-26-2007, 07:36 AM
Cuda_jim's Avatar
Cuda_jim Cuda_jim is offline
Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.
That's pretty amazing that it starts easily at 44f without a GPR.
BTW: No damage will occure with it disconnected...just more difficult to start, well not for you though.
Old 10-26-2007, 07:40 AM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
Good batteries , good starter,,,Great compression....
I have a case loader that always needed starting fluid , year round , until I changed the starter....
Old 10-26-2007, 07:52 AM
MADVAN's Avatar
MADVAN MADVAN is offline
MADVAN has a very good reputation on FTE.MADVAN has a very good reputation on FTE.MADVAN has a very good reputation on FTE.
Its a quick and easy repair.
Seems the GP system along with the EBPV system start to have a use at 46* and below. Above that they are not needed. Just my findings.
Bill
I always thought that I had good working Glow plug system, until I realized that dash voltmeter was not indicating disengagement of the GPR.
after testing it out I knew it was bad.
I know I might get in trouble when it dips below freezing but I could always jump the GPR terminals.
Old 10-26-2007, 07:57 AM
I don't want to put a whimpy stock GPR and aftermarket I have seen so far don't come with that pigtail connector that I got.
Bill
Old 10-26-2007, 08:00 AM
Is that a Cali model GPR?...
Old 10-26-2007, 08:02 AM
Truck is 96 Cali model.
My 97's GPR is way diffirent.
Quote:
Old 10-26-2007, 08:04 AM
Quote:
See the link in post # 2 for an extremely heavy duty relay
Old 10-26-2007, 09:32 AM
otpracer100 otpracer100 is offline
otpracer100 is starting off with a positive reputation.
Only my opinion but, the part is cheap it,s easy to replace and (the wimpy stock one) lasted this long so I would just do it!
Old 10-26-2007, 11:05 AM
Cuda_jim's Avatar
Cut off the connector and splice the wires to the GPR. Doesn't matter which posts you put them on.
Old 10-26-2007, 11:54 AM
MLCinNCTX MLCinNCTX is offline
MLCinNCTX is starting off with a positive reputation.
I am not sure what is wimpy about the stock GPR. The current one on my truck has been on for five years and 150k miles, but it could break today.
Old 10-26-2007, 09:11 PM
Wimpy= not reliable, high fail rates, high currnet draws, terminals snapping.
I too thought I had a reliable GPR, since my truck had no problems starting at around freezing temps. until I found out.
Quote:
Old 12-01-2007, 02:03 AM
Well,
It has hit 31-35 F and around that here at night. And starts Up fine.
If it has been sitting overnight or more that 20 hrs than it starts on the second try.
After I swithced to White bottle of Deisel Kleen than all it takes is one try.
Pretty cool, I think
Mast be good compression in that engine.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
